Old 12-06-2009, 04:41 PM   #1
bradf74
TH 350 shift seal leaking..Tool?
I know there is a tool to remove the shift seal on a th350 without dropping the pan, but I can't find a reasonable one. I have looked locally and on the net. I found one for $42 plus shipping online, but there has to be a cheaper one. Any vendors out there?
bradf74 is offline   Reply With Quote
Old 12-06-2009, 04:49 PM   #2
cableguy0
Re: TH 350 shift seal leaking..Tool?
its a specialized tool most guys that spin wrenches everyday dont have it. thats probably the cheapest your going to find it. theres also an installer bc its tough to get it back in there without destroying it
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 12-06-2009, 05:29 PM   #3
westofb
I really hate wet sanding!
westofb's Avatar
Buy one at local parts store, use it, clean it, and return for a refund!
Jeff,
68 C-10
75 C-20, now a C-10!
10 F-150
westofb is offline   Reply With Quote
Old 12-06-2009, 07:48 PM   #4
Byronic
The Beach Cruiser
Byronic's Avatar
I will loan you mine. You pay shipping to and from. Pm if interested. After all, if your on this site your good people, right?
1999 Silverado DD
1966 Panel Truck
2003 Harley Road Glide
1967 Schwinn Tandem Single Speed
Byronic is offline   Reply With Quote
Old 12-06-2009, 07:50 PM   #5
3r!c84
Badass
3r!c84's Avatar
got any pic of what this looks like? i have the same problem
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 12-08-2009, 02:38 AM   #6
benntn
benntn's Avatar
How do you know where it is leaking? Mine trans leaks too but I'm not sure where or how to find the leak.
benntn is offline   Reply With Quote
Old 12-08-2009, 06:22 PM   #7
bradf74
Thanks for the offers, but I finally found it locally for $40 with the installer tool. I decided just to bite the bullet and get the $^%^& thing.
I am pretty sure it is the seal because that is the highest thing on the tranny that has fliud on it. Clean the entire tranny real well and look around the seal. Mine also had fliud on the arm that comes through the bracket on the shift shaft. Since the truck doesnt move yet, I figured there is only one way it could get there
Old 12-08-2009, 06:53 PM   #8
3r!c84
Badass
3r!c84's Avatar
can anyones tell me or show me what it looks like.and how it works
-00 Saturn 5spd
1/4:13:90
Old 12-08-2009, 07:27 PM   #9
bradf74
Google it. There are a couple of pics online.
Old 12-08-2009, 10:39 PM   #10
bradf74
http://www.transmissionpartsusa.com/...-000jt1001.htm
This is it
Old 12-08-2009, 11:17 PM   #11
3r!c84
Badass
3r!c84's Avatar
ok i see but i dont get how that pulls the seal out with out droping the pan
-00 Saturn 5spd
1/4:13:90
Old 12-08-2009, 11:29 PM   #12
Byronic
The Beach Cruiser
Byronic's Avatar
Everything in in the instructions. Took me 5 minutes to remove and install.
1999 Silverado DD
1966 Panel Truck
Old 12-09-2009, 12:21 AM   #13
benntn
benntn's Avatar
Brad is your transmissions AT or manual? Take pictures too please when you change it.
Old 12-09-2009, 07:36 AM   #14
3r!c84
Badass
3r!c84's Avatar
th350 is auto
-00 Saturn 5spd
1/4:13:90
Old 12-09-2009, 09:52 AM   #15
68 TT
Still plays with trucks
68 TT's Avatar
Where did you find it locally?
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 12-09-2009, 03:31 PM   #16
bradf74
Funny you should ask..
I have a buddy who is a peterbuilt mechanic. I was talking to him about the puller the other day and he said he would do some checking with mechanic buddies. He could not find one either. He called and said his "tool guy" could get it for $40 and I took the deal. I honestly do not know the exact source from where it is coming. He should have it by the end of the week. I will post back with the manufacturer and part number.
Old 12-09-2009, 03:38 PM   #17
68 TT
68 TT's Avatar
Thanks, I appreciate that. I know I have a few leaking seals that could take care of.
Old 12-17-2009, 07:44 PM   #18
bradf74
For all those interested (or searching this subject months from now) it is a matco tools #9648. Took about 5 minutes. Just knock the threaded end of the remover tool into the seal and give it a couple turns to "bite" into the old seal. Use the bolt provided as a press to pull the old seal out that is now attached to the threaded end of the remover tool. Then use the installer to knock the new seal into place. Nothing to it.
Old 12-17-2009, 08:01 PM   #19
3r!c84
Badass
3r!c84's Avatar
how would you change it out with out that tool? i know drop the pan.but then what?
-00 Saturn 5spd
1/4:13:90
Old 12-17-2009, 09:05 PM   #20
bradf74
No clue... That is why I spent $40 on the tool.
Old 12-17-2009, 09:24 PM   #21
rigon4
rigon4's Avatar
I know on a th400 without the tool you drop the pan unbolt the shifter linkage inside and remove it from case use a pick to get the old seal out and to put the new one find a deep well socket that is close to the same size as seal to tap it in.
1981 K-5 Blazer 2wd
1985 C-10 Short step
1988 C-10 Suburban
rigon4 is offline   Reply With Quote
Old 12-17-2009, 09:27 PM   #22
3r!c84
Badass
3r!c84's Avatar
yeah its a .75 cent part and 40$ to put in? bs
-00 Saturn 5spd
1/4:13:90
