Old 12-06-2009, 07:56 PM   #1
asphaltburner
asphaltburner's Avatar
FRONT wheel drive!
Yo! Y'all!
Just out in the FRANKENTRUCK in about five or six inches of snow,…15 degrees, and in FRONT wheel drive! Did just fantastic!
Amazing how the vehicle no longer feels like a P/U when in front wheel! The truck acts like there’s more traction, steering, and acceleration available. That "slippery rear end trying to get out front" feeling just disappears.
Feels JUST like front wheel drive cars I’ve driven in the past.
I do notice that around fifty-five, I get some minor vibration that I don’t feel in RWD, but 4x4 and FWD are meant for extremes and snow, so higher speeds are not an issue. And that’s a lot of torque and horsepower to turn 180!
I’m in the midst of troubleshooting my fuel gauge/sender, so I’m doing a study of the system. I have a working '78 fuel gauge that I’ve tested using a 9V battery. Positive is right, sender left, and ground bottom. Sender open results in the gauge pegging past full, grounding it pegs the gauge below empty.
If it ever warms up a bit, I'll test my new rear half of the system (rear of the fuel sender in-line connection near the starter) with the gauge. The front half has already flunked the grounding test,...my in-dash gauge remains pegged beyong full constantly (no connection, "open"). I suspect the instrument panel plug connection,...a common source of problems in GMs.
More soon on the fuel sender business.
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
Old 12-06-2009, 08:06 PM   #2
3r!c84
Badass
3r!c84's Avatar
Re: FRONT wheel drive!
you put it in 4x4 and took out the back drive shaft?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 12-06-2009, 08:15 PM   #3
asphaltburner
Yo! Sorry, I shoulda guessed some might not remember FRANKENTRUCKs' configuration.
I combined a proven 350 V8 build of mine, a TH400 with 1200rpm stall, and a machined twin-stick NP205 with Warn hubs.
FRANKENTRUCK can brag RWD high/low, 4x4 high/low, and FWD high/low.
Today was an excursion in FWD high over powder and packed snow. Just amazing!
Todd.
Old 12-06-2009, 08:17 PM   #4
3r!c84
Badass
3r!c84's Avatar
ohhh thanks im not educated in the 4x4 thing so thanks for helping me out
-00 Saturn 5spd
1/4:13:90
Old 12-06-2009, 08:26 PM   #5
asphaltburner
Yo! The NP205 is an older gear driven transfercase and is quite tough! Off Road Design in Carbondale, CO rebuilds and machines NP205s to twin-stick, giving them the capability to independantly control the front and rear axles, giving them the capability I refer to. Other companies do this, and a rebuilder can do it also.
FYI.
Todd.
Old 12-06-2009, 08:27 PM   #6
3r!c84
Badass
3r!c84's Avatar
do you still have to get out and lock the hubs.or just put it in FWD and go?
-00 Saturn 5spd
1/4:13:90
Old 12-06-2009, 08:46 PM   #7
b454rat
If you have lockout hubs, then you need to turn the dials. If you have slugs, it's "on" all the time. Or if you have the selectables, only when the front driveshaft has power do they lock.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 12-06-2009, 09:20 PM   #8
asphaltburner
Yo! I prefer getting out and locking the front hubs for FWD and 4x4,...it gives me the chance to check the road surface for traction. If it's ice, then you'll know it!
If I wanted to, I guess I could leave my front hubs locked in, but this way I'm not driving my front axle and shaft constantly.
Todd.
Old 12-08-2009, 02:14 AM   #9
2tons of fun
FYI.
Todd.
and any one else with a grinder and 1hr.
i have done 3 setups so far.
it real pimp to have 3!! shifters for your transfer case, it just gets old have to explain it to everyone.
2tons of fun is offline   Reply With Quote
Old 12-08-2009, 02:17 AM   #10
2tons of fun
did you make sure that you cant accidently shift in to high/low at the same time?
Old 12-08-2009, 02:41 AM   #11
willett
Another Day, Another Dollar
willett's Avatar
hey is there any way that you can put a picture up of your sticks?
is it possible to do that to a 203?
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 12-08-2009, 02:59 AM   #12
2tons of fun
no, you can not get front only from a 203, because 203 are super :rainbow:.
people do twin stick them though because the factory shifter is junk, but it only gives you high/low 4x4 or high/low 4x4 loc, just like stock but you are locking it it with a seperate stick.
ther is only one way to get front only from a 203, its a 203/205 doubler, then you get 3 sticks.
