Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1988-1998 GMT400 Chevy & GMC Pickups Parts Board
Old 12-06-2009, 08:41 PM   #1
WIDESIDE72
WIDESIDE72's Avatar
1-LT4, 2- Vortec 350 cams for sale
The first pic is the GMPP LT4 roller cam has the long pin in the end. I think this is for use in an LT1 with Opti Spark. I ran it for about 500 miles in a Vortec 350 before swapping in a Comp Cam RV grind for more torque. sold
The second two are stock Vortec 350 cams. One has around 60k miles. The other was in the rebuilt Vortec short block I bought. I'm not sure if the rebuilder did anything to it or not. $50 each + shipping
High volume oil Pump for 350 Vortec, around 500 miles on it. $20 + shipping
New stock type Vortec 3 pc.single roller timing set ( cam gear, crank gear and chain SOLD
WIDESIDE72 is offline   Reply With Quote
Old 12-06-2009, 08:43 PM   #2
WIDESIDE72
WIDESIDE72's Avatar
Re: 1-LT4, 2- Vortec 350 cams for sale
I have been told that the Vortec cam is a good upgrade to a TBI engine, as it has almos the same specs as an LT1 cam (?)
The LT4 cam is better suited to a Camaro, Impala SS, Caprice or light 2wd 1/2 on pickup.
Old 12-07-2009, 07:54 PM   #3
44th Miss Inf
Can I get more info on the timing chain (manufacture, etc) sent to virgilroberts (at) hotmail.com
44th Miss Inf is offline   Reply With Quote
Old 12-08-2009, 08:06 PM   #4
WIDESIDE72
WIDESIDE72's Avatar
I thought I took pictures of the timing set, but I guess i didn't. It is a stock Cloyes set. The top gear can be seen in one of the pics above. It is for use with Vortec and LT1 cams, not Gen 1 cams. it has a different mounting pattern. I will take some pics as soon as I can.
Old 12-13-2009, 08:16 PM   #5
WIDESIDE72
WIDESIDE72's Avatar
Ttt
Old 12-15-2009, 09:45 PM   #6
WIDESIDE72
WIDESIDE72's Avatar
Pics of timing set
Old 12-15-2009, 09:47 PM   #7
WIDESIDE72
WIDESIDE72's Avatar
The timing set in the pics was on the rebuilt short block I bought, but I saw no sense in using it, since the timing set off the "Old" engine only had around 500 miles on it.
Old 01-26-2010, 08:18 PM   #8
WIDESIDE72
WIDESIDE72's Avatar
Ttt
Old 05-16-2010, 12:38 PM   #9
WIDESIDE72
WIDESIDE72's Avatar
LT4 cam and timing set sold. Vortec cams and oil pump still available
