Old 12-07-2009, 12:27 AM   #1
MobSled
MobSled's Avatar
1977 vs. 1984 Suspension
Wondering if the lowering kit from a 1984 shortbed would fit on a 1977 longbed???? Shakles, shock extenders, leaf pack, blocks, U bolts, springs, swaybar etc....
MobSled is offline   Reply With Quote
Old 12-07-2009, 12:30 AM   #2
bigblock73
yeller
bigblock73's Avatar
Re: 1977 vs. 1984 Suspension
Spindles will likely be different (1" and 1.25" rotors), and there are two different length leaf springs...other than that, most should be interchangable.
bigblock73 is offline   Reply With Quote
Old 12-07-2009, 12:33 AM   #3
MobSled
MobSled's Avatar
No spindles included, just 3 inch lowering springs. So the leafsprings wont fit from a short onto a longbed?
Old 12-07-2009, 12:36 AM   #4
flamingbig10
6.0 powered square
flamingbig10's Avatar
no just depends if there 52" or 56" long
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 12-07-2009, 12:38 AM   #5
MobSled
MobSled's Avatar
I`m assuming 56" will fit and the 52s wont?
Old 12-07-2009, 12:38 AM   #6
bigblock73
yeller
bigblock73's Avatar
The length of the bed has nothing to do with it (as previously mentioned, there were two diff length available)...you will have to measure to be sure.
Old 12-07-2009, 12:40 AM   #7
bigblock73
yeller
bigblock73's Avatar
They will both physically fit, but you'll have to relocate the rear hangers if you change the length of the springs in your truck.
Old 12-07-2009, 12:40 AM   #8
MobSled
MobSled's Avatar
I get it pretty much meassure my leafs and get the meassurements off the 84...if its the same length it`ll fit.
Old 12-07-2009, 12:41 AM   #9
MobSled
MobSled's Avatar
They will both fit, but you'll have to relocate the rear hangers if you change the length of the springs in your truck.
Gotcha...everything else as in the front lowering springs is the same and will go right on?
Old 12-07-2009, 12:42 AM   #10
bigblock73
yeller
bigblock73's Avatar
Bingo! An easy way is to look and see where your rear hangers sit on the frame. If they are tight to the bumper brackets, you have the long springs...if there is about 4" between the hanges and bumper brackets, you have the short springs. Measuring is always best, but this will tell you easily as well.
Old 12-07-2009, 12:43 AM   #11
MobSled
MobSled's Avatar
Anything on the front lower swaybar?
Old 12-07-2009, 12:43 AM   #12
MobSled
MobSled's Avatar
No matter what I can make both lengths fit by relocating the hangers?
Old 12-07-2009, 12:44 AM   #13
bigblock73
yeller
bigblock73's Avatar
Should. The only thing is the sway bar...if both trucks have one, then easy...if your truck doesn't, you will need to remove the mounts on the donor (they are riveted on).
Old 12-07-2009, 12:44 AM   #14
bigblock73
yeller
bigblock73's Avatar
Yes, but it is a PITA. They are riveted on.
Old 12-07-2009, 12:48 AM   #15
MobSled
MobSled's Avatar
Wow you guys are great...love this forum. Everytime I needed answers I got them in matter of minutes. Really appreciate all the help.
Old 12-07-2009, 05:38 PM   #16
kevinr1970
Not to sidetrack, but why is there two different springs?
Is it 1/2 ton vs. 3/4 ton, 1/2 vs HD 1/2 (or "big10") or is it something else?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
