Old 12-07-2009, 12:51 AM   #1
shrtbx
rear end problem?? i just notice only one tire burns out.
I dont do it too often. But i noticed that i only have one tire burning out from what i see on the pavement. Does that mean i have some unforseen problems? Or does it mean i have a certain type of rearend. Its a stock 3:08 ..86 short bed.
shrtbx is offline   Reply With Quote
Old 12-07-2009, 01:03 AM   #2
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: rear end problem?? i just notice only one tire burns out.
Perfectly normal. Open rearend or a broken posi type but not likely
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is online now   Reply With Quote
Old 12-07-2009, 01:05 AM   #3
82swampthing
82swampthing's Avatar
you probly have a open differential which means only one wheel gets power but when you go around corners it lets one wheel slow down and the other speed up so the tires don't chirp while turning like a locker or spool in your rear end would .or you might have a limted slip differential thats worn out and the clutches inside are not grabing giveing power to both sides when you go in a straight line.
R.I.P gm 1908-1986
1982 chevy k20,350,sm465,np205,10bolt and 14bolt s.f
82swampthing is offline   Reply With Quote
Old 12-08-2009, 10:53 AM   #4
spaseghost
certified tard
spaseghost's Avatar
yes, those things suck. my wife is awesome so she is looking for an ebay one for me for christmas.
85 swb bbc 5% tint
16.356 @ 84.81 8/07/09
4800 Ft., bad timing, carb tune, and traction, fugg it.
16.169 @ 84.29 8/28/09
good timing, no carb tune, some traction...
06 Equinox LT AWD, wife's and family ride
03 Mustang V6, CAI, Duals, Pullies, Programmer, Short Throw, wife's dream car?!
90 Eagle Talon, other project / space taker, GOT head!!
08 Silverado 2500 HD, the bad ass work truck
spaseghost is offline   Reply With Quote
Old 12-08-2009, 11:08 AM   #5
TwoFiftyShifter
I have a similar problem with my rear end.... It's a posi rear, confirmed only by spinning the tires in loose dirt and seeing two tracks.... But sometimes If I head out to the backyard, only the right rear spins....
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 12-08-2009, 11:50 AM   #6
flamingbig10
6.0 powered square
flamingbig10's Avatar
then you might have a limited slip
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 12-08-2009, 02:18 PM   #7
nlped
nlped's Avatar
^^^ A worn out Limited Slip?
Can they not be rebuilt, or is it more cost effective to just replace with a more modern version?
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 12-08-2009, 05:24 PM   #8
Rede
I too have an open semi floating diff, but the price of getting an eaton or simular limited slip unit is almost as much as I paid for the truck. = \
I did however run across something called powertrax locker:
http://cgi.ebay.ca/GM-9-5-CHEVY-14-B...item35a32411fa
Would this unit function like a limited slip unit in town, simulating an open diff on the street while giving the benifits of a locker in the mud... or does this type of unit stictly a locker...?
The description wasn't all that clear to me.
Rede is offline   Reply With Quote
Old 12-14-2009, 09:48 PM   #9
silverbullet01
on fire one tire :P
silverbullet01 is offline   Reply With Quote
Old 12-14-2009, 09:58 PM   #10
82chevy350
82chevy350's Avatar
Just use a mini spool there like $30 Bucks
or the cheaper way is to weld your spyder gears
haha id buy the spool
Drive It Like Ya Stole It
'82 Primer White c10 2wd LWB 350 sbc t350
(Hot Rod)
'90 2wd LWB Silverado 350 tbi 700R4
(Daily Driver)
'53 m38a1 Willys Jeep
(Toy)
82chevy350 is offline   Reply With Quote
Old 12-14-2009, 10:24 PM   #11
Rede
I was told not to get a spool for the trails because your diff tries to push the backend around each corner and makes it harder to corner in tight spots...
I have yet to find a 30 buck spool locally.
400+ here for new and haven't found a used one for a 9.5" 14bolt.
Old 12-14-2009, 10:39 PM   #12
82chevy350
82chevy350's Avatar
didnt know he was using it for trails
(Hot Rod)
(Daily Driver)
(Toy)
Old 12-14-2009, 11:25 PM   #13
3r!c84
Badass
3r!c84's Avatar
i got a one wheel wonder lol its great :p
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 12-15-2009, 01:55 AM   #14
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yep haha 1 wheel wonders!!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 12-15-2009, 02:28 AM   #15
Rede
OP didn't actually specify, but I was just pointing out that a posi or welded diff may not be optimal under all conditions.
Old 12-15-2009, 02:35 AM   #16
Malo83
Cruzzzn' Vet
Malo83's Avatar
Peg leg hear that the PowerTrax might be the way to go for that Peg leg on your truck
http://www.powertrax.com/powertrax/noslip.html
Malo83 is offline   Reply With Quote
Old 12-15-2009, 10:01 AM   #17
68 TT
Still plays with trucks
68 TT's Avatar
A spool is dangerous on the street. I have done it a little moving race cars around the house and in the pits at the track. You have to be very careful when moving slow and turning corners it will push the car around in ways you don't want it to go when trying to maneuver it around slowly. It is very hard on the tires.
On the street it would get you a ticket every time. The tires will chirp heavily when you corner on dry pavement.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 12-15-2009, 07:18 PM   #18
Rede
I found one on ebay a few weeks back for 150, but I was told to wait till after christmas before buying anything truck wise.. now the cheapest one is 450 bucks. /pout
Old 12-16-2009, 12:45 AM   #19
Rollinsqrbdy
Rollinsqrbdy's Avatar
what bout welding up the gears, any one done that? It dont sound to good.
Its Kool to be a square
2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's
1985 C-10 ......My dream truck (under construction)
1984 k 10 Silverado...6" lift with 38.5 super swampers
New Mexico Member
--- Member of the Square Body Club---
Rollinsqrbdy is offline   Reply With Quote
Old 12-16-2009, 01:57 AM   #20
Rede
I know drag racing with a welded rear is a big no-no but no one has really told me why...?
Old 12-16-2009, 02:40 AM   #21
78 Chevyrado
a Broken LSD or Posi or an open rear end... My trucks a peg-leg, but it leaves two tracks in dirt or gravel. Jack up the rear end (both wheels at once) and spin a tire. If the wheels turn in opposite directions, it's an open rear. if they spin in the same direction, it's a posi.
78 Chevyrado is offline   Reply With Quote
Old 12-16-2009, 02:52 AM   #22
shrtbx
I was hoping to stick some 3:73 gears in the back. But now i dont know. Is it worth it?
Old 12-16-2009, 03:20 AM   #23
2tons of fun
wth? why would any one tell you its a bad idea?
welding a rear is strictly a hard core drag move. why do you think rear drag cars also run spools?
a welded rear sucks driving street/daily and is flat out scary in the wet especaily if you have power. i busted a posi and switched to a welded rear, i spun out at 30-40 taking a corner in dry good conditions, i took it back out. it is very noticable and and for me made the truck no fun to drive.
2tons of fun is offline   Reply With Quote
Old 12-16-2009, 11:55 AM   #24
68 TT
68 TT's Avatar
^x2
A welded rear or a spool in a street car is just plain dangerous. Cornering at more than a crawl with both rear tires rotating at the same rate = an accident waiting to happen.
In a street car with a welded rear end you would be lucky not to break an axle while making a sharp turn trying to park the thing.
Old 12-17-2009, 03:09 AM   #25
Rede
Re-read my post. lol
I was speaking about drag racing purposes in where you want both wheels grabbing traction all the time.
I was wondering if the diff is prone to weakening or if they violently grenade, ect.
