Old 12-07-2009, 12:59 AM   #1
PJsthnam
PJsthnam's Avatar
Yes...another tire question
Ok, I'm not a truck guru like most of you guys. But I was wondering what the narrowest tire I can (or should) go with on a 3/4 ton 2WD? I have 265/75 16's, but I kinda like the narrow tire look. I wanna stay around 32" height. I have found that 235/85 16's are just a hair taller. But is this too narrow? I would be going from about 10.4 to 9.25"s tread width. I'm not sure what the load rating is spec.'ed for my truck.
72 GMC Custom Camper
84 Shovelhead
PJsthnam is offline   Reply With Quote
Old 12-07-2009, 01:12 AM   #2
dan42
dan42's Avatar
Re: Yes...another tire question
Depending on what you intend to use the truck for, I guess, will depend on how narrow of a tire you can go. If you are going to use it as a work truck and load it, then I would not recommend thinner tires. You compromise many things when you go to a narrower tire, and load rating, and possibly safety, are among them. I would not run anything narrower than what is recommended by the truck's specs.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 12-07-2009, 01:15 AM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Quick check shows BFG All Terrain 238/85-16 to be same height as 265/75-16, and available in LR-E, max load 3042# @ 80 psi. It will carry anything your truck can handle.
Too narrow? No, not if you're looking for a narrow tire....
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
