Exhaust tube Diameter
Well it's me again needing a little help from my Chevy community. Question of the day for me is now, that i have these new high dollar headers for my 79 c10. What size pipe to run for around 450 to 475 flywheel horses, yes i like the 3" but do i really need to go that big for this? I was told by some that 3" will give me more noise. Looking to not upset neighbors but dont wanna choke off my truck either going to small or getting 3" and not need it. The headers are the Hedman 1 3/4 runners down to which ever collector i wanna use 3 or 2.5.
On a budget like Fred Sanford
Re: Exhaust tube Diameter
At that power level you are getting close to the point where you need 3" duals, but 2.5" duals will support it if that's the route you choose. Use mandrel bends and good flowing mufflers. I'm at the same power level as you and went with 3" duals just so I know I don't have a restriction and have room to grow. They definitely are a little louder than 2.5", but muffler selection will have some to do with that as well.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
#3 | |
'79' shortbed |
I'm running 3" duals on mine and they are a little loud but more of a deep tone. I's say go with the 3" duals. That should be great for the ponies you're runnin.
Another Day, Another Dollar
i quite enjoy my 3" duels.
my neighbours do not.
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" ![]() |
Still plays with trucks
^x2
Adding tail pipes to my 3" dual system on the C-10 that used to be turned out in front of the rear wheels really dropped the noise level down. It sounds nice now when before it was a little loud and you didn't really get much of that classic Flowmaster sound. I used to knock things off the wall of the neighbors house when I fired it up, with the full tail pipes it just shakes the windows when I drive away. It has much more of the classic Flowmaster sound now. Flowmaster makes a nice 50-series SUV performance muffler that will help quiet it down a little vs. the traditional 40-series muffler. I really like the way they sound on my Malibu and have a set I am putting onto the 68 Camaro.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
For mufflers you might try the Aerochambers. I know quite a few guys on here a couple years ago were switching to them and liked them a lot. They have a straight through design where the Flowmasters do not.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
#8 | |
Nothing against flowmaster they are great but just want something different. |
I think i will do the 3" just run a different muffler, flowmaster also makes a 70 series that is next to the hushpower, but i was told they are to heavy and often break hangers. 3 i think is the way to go though. Thank you alot.
#10 | |
is anyone having RESONANCE problems with the larger pipes?
Only in the walls of the house before i put the tail pipes on. It was way louder in the house than it was outside. Kind of weird.
#13 |
I cant say anything bad about flowmaster they sound great, its just that over here everyone has the same sound. I wanna be a little different.
#14 | |
You could do a search for Aero Chamber on youtube and probably find a few video clips so you can hear them.
#16 |
Master Hater
Do you have a dyno slip saying you make that much? Not doubting you, but i see alot of folk slap on alot of bolt on and stuff and think that all the crap added togeather adds up to 400HP..lol when really its maybe 30.added HP. post up a list of what you have done. really for anything streetable with decent HP you only need 2 1/2 dual , you really want to keep the exhaust gas velocity up so it helps pull everything out of the Cyl when the exhaust valve opens up. good article to read about exhaust.
http://my.prostreetonline.com/forums...ead.php?t=1639 |
#17 |
Badass
i got 2 1/4 in pipeing with flowmaster 40s.how much hp will i piick up when i put in the longtube headers?
its just a 305 with nothin that good in it
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
#18 |
Not much with a stock 305. Maybe 5 hp. 10 if you are lucky.
#19 |
I'd run a 2.5" y-pipe into a 3" single
1972 GMC C10 Last edited by Manbearpig; 12-09-2009 at 07:33 PM. |
#20 |
Go 3". I'm a Magnaflow fan. I like the smooth, mellow sound.
Jay 1978 Big 10 Silverado, 355 + 700R4 + 3.42 + factory tach + A/C + dual tanks + working cruise control = awesome highway cruiser. |
