Old 12-07-2009, 01:47 PM   #1
azngosh8r
azngosh8r's Avatar
Need help re: 71 Blazer Engine Mounting
Pulled the 454 engine in my 1971 Blazer and got it rebuilt...problem is:::
i dropped it back in and mounted it up but the valve covers are too tight up against the firewall...just no way it could be right! not even room for some engine movement.
do the mounting brackets have a right and left side? could i have them backwards?
seems like it should be easy, the block and frame only have one set of holes?
lost...
Russ Ellis
'Cruizin' the Valley' - Custom Classics
"The Guyz Garage"
azngosh8r is offline   Reply With Quote
Old 12-07-2009, 03:03 PM   #2
turp mcspray
turp mcspray's Avatar
Re: Need help re: 71 Blazer Engine Mounting
What changed while it was out? Did you go with different valve covers, heads,etc?
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 12-07-2009, 03:48 PM   #3
azngosh8r
azngosh8r's Avatar
no changes at all...new valve covers but same style and shape....thats what has me confused...i feel like im losin my mind...
Old 12-07-2009, 04:37 PM   #4
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
The valve covers are probably a little taller/different.
68SWB4x4 is offline   Reply With Quote
Old 12-07-2009, 09:56 PM   #5
turp mcspray
New motor mounts? Something HAS to be different. It's probably something simple.
Turp Mcspray
