torquing tie rod ends / draglinks
I just replaced my draglink, but I can't torque the castellated nut because the new draglink post spins in its seat. I plan to do tie rod ends next and expect they will spin as I try to torque, as well. How do you torque these nuts if the post spins? Thanks.
RLTW 70C10 72K10 72K10 Cheyenne 72C10 Cheyenne Super |
Take a rubber hammer a "tunk" your tie rod end while you turn the wrench. I have used an air wrench to run the nut down. Once the nut is down, you can tighten it with your torque wrench.
Jim |
go bucks!
what the hell is a "tunk"?
'68 swb 1/2t 350/350th '86 lngbd 3/4 TON parts getter '49 gmc 1/2 t 5 window 350/350th '96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know? |
OK, Jim - thanks! I knew somebody would have a "trick" for that.
