Old 01-23-2003, 10:12 AM   #1
mrein3
mrein3's Avatar
Question Wrong Window Sweepers?
I bought a new door for my truck a few years ago. I took everything off it, painted it inside and out to match my truck, and then put it back together with new window channel insulation and the "sweepers" that go along the top edge of the door. I bought pieces from LMC. I tried to be fancy and went with the sweepers with the chrome trim. When I got the door all back together with the chrome trimmed sweepers it was and still is very hard to roll down the window. I figured it was just a worn out window regulator because I put a new roller on it while I had it apart and figured I just screwed it up.
The other door's window rolled up and down with no problem.
I ran across the other half of the re-pop sweepers set in my garage the other day and installed them in the other door. Now it too hardly rolls up and down.
Are the chrome trimmed pieces different than the plain jane ones? I guess the real question is should I spend the money and get a new set of the non-chrome ones or will I still have problem and just be $20 or $30 lighter.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 01-23-2003, 11:03 AM   #2
JimKshortstep4x4
Talking
Some widow fuzzies need to be trimmed, especially at the rear where they interface with the rear window run. You can force the window run into the window and it can bind. I would look at both ends to see if additional trimming is needed.
Jim
Old 01-23-2003, 11:40 AM   #3
mrein3
mrein3's Avatar
I did the driver's door first. I noticed that some trimming was necessary and did that on the passenger side. With the trimming it still is almost impossible to roll up and down. That is what makes me wonder if it is the piece itself.
'72 Malibu hard top
Center City, MN
Old 01-23-2003, 12:11 PM   #4
Frank_Zeller
Frank_Zeller's Avatar
I'm having the same problem. Window binds on the rear slider. I did notice that most of the felt came off of the rubber. Repops repro.
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 01-23-2003, 01:19 PM   #5
Lippyp
English Chevy Owner
Lippyp's Avatar
At least yours contact the window, the ones I bought from Chevy Duty don't seem to actually touch the glass and consequently don't do much about keeping the water out! (we have an abundance of water delivered fresh daily from the sky here in the soggy UK)
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
