Old 12-07-2009, 05:17 PM   #1
cedorris
1972 Chevy Cheyenne Super
cedorris's Avatar
KBS Frame Coater?
Has anyone used the KBS Frame Coater Kit?
I want to hear all about it. I'm considering it for me 72. Do I need to wire brush the frame or will the rust remover really work as well as advertised?
Is there any national chains that carry it or do I have to order it from their website?
-Clayton
1972 Cheyenne Super LWB 350 - farm truck restore project - twitter @oldgreen
cedorris is offline   Reply With Quote
Old 12-08-2009, 06:11 PM   #2
cedorris
cedorris's Avatar
Re: KBS Frame Coater?
BUMP!
I know someone has to have used this product....
-Clayton
Old 12-08-2009, 09:39 PM   #3
mvfd70
mvfd70's Avatar
I used it. I've only done one frame though. So I can't tell how it compares to other products. It seemed to go on pretty good though. Laid out smooth. We'll have to see how well it holds up when I get the truck on the road.
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 12-09-2009, 01:27 AM   #4
cedorris
cedorris's Avatar
How did you prep the frame? Did you use the included cleaner and rust remover or did you have it blasted?
-Clayton
Old 12-09-2009, 09:30 AM   #5
mvfd70
mvfd70's Avatar
I had the frame sandblasted. The included cleaner and "Etch" stff works ok but it went on a lot smoother over the blasted metal. Be sure you wash the frame thoroughly if you sandblast it. I missed a couple of spots and now I have some sand stuck in the paint. That part is going to be covered so no one will see it, but I know it's there.
Also, pay attention to the temperature and humidity. I had to redo a couple of pieces because I got too impatient and it was too humid outside. The stuff really bubbled up and didn't set well. I had to use Aircraft Stipper to get it off and it was still hard to remove. When applied properly it looks great and lays out smooth as glass. Any problem I've had so far has been my own fault.
Old 12-09-2009, 02:09 PM   #6
HOOPTY67
i've been impressed with all of KBS' products so far. the Aqua Clean and Block Coater worked especially well.
-mike
HOOPTY67 is offline   Reply With Quote
Old 12-09-2009, 03:07 PM   #7
Normy71
I used it great stuff.
I had my frame sand blasted first covers nice
only problem I found is if you open a can it is hard to reseal proper?
better to pour it into some other container.
I understand it was the same chemist who made POR15 started this stuff?
Rolled the dice and lost!!
Check Out my 71 build
http://67-72chevytrucks.com/vboard/s...d.php?t=375158
Normy71 is offline   Reply With Quote
Old 12-09-2009, 03:23 PM   #8
cedorris
cedorris's Avatar
Seems like everyone who has used it, has blasted the frame.
Due to lack of space and resources I can't blast the frame. Is the included prep stuff good enough for the job?
I'm going over the entire frame with a wire wheel.
-Clayton
Old 12-09-2009, 03:25 PM   #9
cedorris
cedorris's Avatar
I assume you mean heat? I will be doing into very soon so it is pretty cold in my garage. Humid isn't a problem.
-Clayton
