SIR
van swap to truck?
just one quick question...will a 76 chevy 1/2 ton "van" work for the front end swap on a friends 65?...thank you
66long low fleet http://community.webshots.com/user/LVNR66 |
#2 | |
Re: van swap to truck?
Are we more confused??
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) ![]() ![]() ![]() ![]() |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Rods
![]() Join Date: Nov 2002
not sure about the 76. i used a 2000 for the six lug it worked. but the tie rods came in from the bottom not the top.
Just keepin it simple. ![]() 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
Some were 5 on5 mostly heavier GVW and "3/4" tons
the early vans used 1/2 ton pu style knuckles and a arms on a wider cross member
I'm doing a front swap on my 54 Suburban using pickup and van parts. I have learned that the A arms (upper and lower) between the pick ups and vans are basically the same except the cross bar on the lower A arm on the van is bigger. I tried a 79 1/2 ton van and a 82 3/4 ton 5 lug and they are both the same. Both are 5 on 5 too.
[IMG] ![]() The vans are on the left. I compared them to a 3/4 ton and they look to be the same size. It will not fit the 1/2 ton. Why not get 73 up ball joints and use the van knuckles? That's what I'm doing. I had some 65 1/2 ton A arms and put 73up ball joints in and bingo. Here's my build thread; http://67-72chevytrucks.com/vboard/s...d.php?t=369297
1970 Nova 327/T5 (my 1st car) 1971 K-20 350/350/205 (winter DD) 1953 GMC Suburban 1968 Chevy Bel Air 1976 Chev C-10 1972 Skylark (suncoupe) 1 of 3943 made Last edited by sweet70beast; 12-08-2009 at 07:37 PM. |
SIR
thank you for all the information,looks like a parts "truck" is in my future.....
i was going to put the front end from a 78 chevy on my 60 chevy, but it was a little too wide for what i liked. althought they got a heavier suspension when they ordered teh van from factory, still 5 lug 1/2 ton tho..i am using a 72 truck front end and drilling the rear axles to 5.
