Old 12-07-2009, 06:58 PM   #1
Bugeyev8
Bugeyev8's Avatar
60-63 Guys, Emergency Brake Cable Help ??
I have searched this site and found nothing I need on this subject...I am not the best searcher...here is what I got 1962 Chevy C10 with a late 70s 12 bolt rear end, I did this swap 15 years ago and tossed away all the old parts years ago. will the stock 62 rear cables work ?
What e brake cables do I use to hook up to the old linkage? the cables that are in the 12 bolt are way too short
I know someone here has had this issue already
Any info would be really great
Thanks, Brian
Bugeyev8 is offline   Reply With Quote
Old 12-07-2009, 09:14 PM   #2
62gmc910
62gmc910's Avatar
Re: 60-63 Guys, Emergency Brake Cable Help ??
Thanks, Brian
My '62 canadian GMC has coil rear , I swapped in a 14 bolt from a 70 something c20 , I used the c20 E brake cables, fabbed some clips to anchor the end of the cable sleeve like the later coil trucks, them made some end to connect to the stock flat bar mechanism and drilled some 3/8 round to slip a piece of salvaged cable from the donor truck measured from the 70s cable to the point my connectors . slipped the cable end thru 3/8 rod measured and brazed the joint, Can't do pics cause the truck is under a snow bank.
hope this helps, post back if I can clarrifly
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 12-15-2009, 09:59 PM   #3
62gmc910
62gmc910's Avatar
couldn' t link
e brake, emergency brake, parking brake
