Brakes?
I have a 1972 GMC P/U. I just changed the rear drum brakes on it and bled the lines because It was still having trouble building up pressure to stop. I noticed under my dash in the cab the rod that goes into my brake fluid reservoir has a bell shaped rubber thing around it. It has brake fluid leaking from it. My question... Is this a problem that should be fixed to help build up pressure when applying my brakes and could this be putting air in my brake lines?? Thanks
Denver ![]() |
#2 | |
Re: Brakes?
