700r4 tranny lockup switch
Ok I have a 700r4 tranny on my 63 c10 off of a 89 rs camaro...I have been doing lots of reading and I am very confused!!!!some people say that on any 700r4 85 or new that there is no need for it to be hook up while others say that it needs to be hooked up regarless of the year or else you risk looosing your tranny.....Can some one please let me know what could happen if its not hooked up ?also is there a kit on the market today that will work with my 63 c10 since there is no computer to hook up the wires coming from the tranny to.thanks
Re: 700r4 tranny lockup switch
If you don't use a lock up, damage can happen to the transmission and converter, not counting your gas mileage will suffer.
http://www.summitracing.com/parts/TCI-376600/
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=346597 https://www.facebook.com/pages/198-C...1434001?ref=hl |
60-66 Nut
![]() ![]() Join Date: Mar 2007
I would suggest hooking it up if you have a lockup converter.
the 700R4 requires a lockup switch or it will generate heat .hooking it up is simple. if you can get the one out of the car the trans came from it would be easier, if not buy one for the model the trans came from. there should be only one wire comming from the 700 , it hooks to the blade terminal on the lockup switch . the switch body needs to be grounded prefferably to the engine block . the hose port on the switch should be hooked to manifold vacuum
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) ![]() ![]() ![]() ![]() |
1961 crewcab
I think I need one of those 80$ summit kits for my 61...
anyone know of a way to do it cheaper? mine is a 2004r
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Registerd User
I have a kit in mine that does away with all electronics. But the id tag for the kit is in my tv spring so I wont be seeing it for about 50,000 miles. Mabey you could find it on line.
ok I have the harness coming out of the tranny....but it has 3 wires not 1....which wire is which?also there is no vacuum line that I see maybe because its of an 89 rs camaro?also will the kit from b&m work?seem you hook up the converter and the speedometer cable..its a b&m kit part#70248..I have been told that the cheap way is with a toogle switch...12 v source and a good ground...however I dont know which wire is which ...Keep in mind that I am a newb at chevy trucks...thanks to all for the quick reply!
#8 | |
![]() Join Date: Aug 2008
Some good info here...
http://persh.org/pickup/UnderTheHood.htm#700R4Tips |
Slots go on anything!
Or here, too: http://www.73-87.com/7387garage/drivetrain/lockup.htm
i will have to find the article , but there is a way you can wire it up using a brake switch so that when you hit the brakes hit will kill the power to the tranny and unlock it. one of the articles i read the guy used and OD lighted switch from a car mounted on the dash to turn the OD on and then ran it through the brake switch.
ahh here ya go http://67-72chevytrucks.com/vboard/s...d.php?t=334345 |
mine is done with a brake switch . it works but is kinda of a pain in the ass driving around town ....it lugs the motor bad unless you ride the brakes somtimes
DOH !!!!!!! |
#13 |
I used the Bowtie Overdrive kit. It was made so the TV cable would work with my Edelbrock carb. (TV cable adjustment is important too) I also got the lockup wiring kit, easy to install and comes with a new brake switch to disengage the lockup. Not cheap but a quality product. Do a web search on them, lots of good info even if you don't buy their kit.
#14 |
Agreed on the BTO site they have some very good products but not cheap. I got my lockup kit from ebay for 45.00 and had to buy wire and fuse but it was very simple all I had to do was tap the servo cover and install pressure switch and wire up.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
#15 |
yeah I guess I am buying the b&m one....its like $159...Im hoping it works and that its as easy as plug and play.......I need it quicky cause the drive is pretty bad....the trannys first goes in quick,second lags,and 3 and 4 I cant hear....
#16 |
Try these guys out, I think they are local for you. "Hesperia, CA"
I talked to them at the GoodGuys show in nor-ca, about the samething. And they have a kit to replace it. http://www.bowtieoverdrives.com/index.shtml ![]() |
#17 | |
![]() Join Date: Jan 2008
The kit you speak of is highly recommended by rodders in my area and is the one I am going to be using myself. Make sure you have a pro at the TV cable adjusting do the TV adjustments for you unless you know for sure what you are doing, that could be some of the reason you are having shifting problems. Reid |
#18 |
X a whole bunch on the TV cable , its the only link to any engine input on this trans. No cable = whoops fryed the trany
