Help! Windshield Seal Leaking
![]() ![]() What brand do you guys recommend? Anyone have good luck with a particular company? I was told that Steele is one of the best. I am willing to not use the trim at all if it will help, however, these trucks came new with it and they didn't leak to my knowledge. Someone help and give me good advise please. Here is a pic of one of the other things that is getting changed. Hope you guys like it. Thanks James
James |
Son of a gun
Re: Help! Windshield Seal Leaking
make sure the installer puts a little dab of silicone in the corners.
Bill BEATERS ARE NEATER |
thanks Bill. I'm sure I'll watch him this time around.
James |
The Older Generation
It shouldn't make a difference whether it has the trim or not. It still shouldn't leak. I used "Precision" brand rubber on the '71 4x4 with trim and I didn't have any problems.
Everything I have heard about Steele has been good. LockDoc
Precision has always been my preference for all my seal products. I have tried the other off-brands and they were not the quality. I agree the trim adds to the difficulty and can increase the chances of leaks. I also have encountered this even with the precision brand. And using a windshield adhesive in the corners is probally the best bet.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
![]() Join Date: May 2007
If you look in the factory assembly manual, they show how the factory used sealer to seal them when new. I always use some 3m Auto Bedding and Glazing Compound. Part #08509. I squirt it into the groove of the rubber that goes over the pinchweld. I have never had a leak doing it this way. I have found that unless the glass shop has an older guy working there, that has experiance with the older vehicles, all they know how to is glue in glass with urethane. If it were me, I'd find another glass guy.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
Thanks to LockDoc, Sammy, and Turp. Very good advice. I believe I am going to stick to the Steele seal, make sure some sealer is used, and see what happens. This time the glass shop is going to pressure sest the cab and make sure that there are no leaks. If they cannot hack it, I will have to take my business elsewhere. Thing is, I will not have my rubber seals back on the truck for a few weeks. I will let you all know what happens.
Thanks once more, James
James |
