Old 01-23-2003, 12:47 PM   #1
1967K10
Question Lift Kit's for a 67K10
I have a 67 K10 I would love to put about three inches of lift under. I have looked in several places and have been unable to find any kits out there. Any ideas where to look?
~Heath
1967K10 is offline   Reply With Quote
Old 01-23-2003, 01:17 PM   #2
breeh
Recovering 67-72 Addict
breeh's Avatar
You can use any of the kits for 69-72 except for the full spring kits. You will have to use blocks on the rear as these are different on 67-68 and nobody makes them. Some people have had custom springs made for this but be prepared to lay out some $$ if you want this. Good luck!
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 01-23-2003, 03:24 PM   #3
Pont
I need another Barley Pop
Pont's Avatar
Exactly what Breeh said. 69 and newer front springs are the same and are readily available. Just buy the lift you want but get it without rear springs. Front springs, shocks, and rear blocks. Be sure to keep an eye on your brake hose length depending on how much lift you go with. If you ever want to lift it without running blocks in the rear (as I did), you will need to have rear springs custom made. 67-68 rear springs are 56" eye to eye and the axle centering pin is centered in the spring pack. 69 and newer are 52" eye to eye and the centering pin is offset. Good luck, keep us posted on what you decide to go with.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 02-16-2003, 12:48 AM   #4
1967K10
Thanks guys, that is exactly what I was hoping to find out. Am working her her it now. Here she is before her lift.
~Heath
Old 02-16-2003, 07:08 AM   #5
meathead95
computer illiterate
meathead95's Avatar
sweet
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 02-16-2003, 08:29 AM   #6
john8746
john8746's Avatar
lift kit
here you go try this
http://rough.roughcountry.com/69-72%...up.htm:bowtie:
C/10 John N.J.
john8746 is offline   Reply With Quote
Old 05-30-2003, 10:38 AM   #7
1967K10
Thanks guys, I am working on getting a kit and rear blocks now
Old 05-30-2003, 11:19 AM   #8
landon4421
Life is Good !
landon4421's Avatar
I am putting a SkyJacker 4" under my '72.:p have you tryed, www.4wheelparts.com yet they might be able to help you.
'72 Chevy C10 4x4 shortbed "Project"
'71 Chevy C10 2wd longbed "partsrunner"
'91 Chevy Burb 4x4 "kidrunner"
'14 Honda Accord Sport "commuter"
landon4421 is offline   Reply With Quote
Old 05-30-2003, 11:33 AM   #9
1967K10
Thanks, I will check them out.
Old 05-30-2003, 11:40 AM   #10
landon4421
Life is Good !
landon4421's Avatar
1967K10 Thanks guys, I am working on getting a kit and rear blocks now
Try and stay away from blocks if you can.
Old 06-12-2003, 05:05 PM   #11
1967K10
Landon,
I am curious to see how satisfied you are with your Skyjacker kit before I buy one. Also, what wheels and tires have you decided upon and what is your clearance like? Thanks.
~Heath
Old 06-12-2003, 05:12 PM   #12
landon4421
Life is Good !
landon4421's Avatar
I have not got the lift on the truck yet. here is a pic of what the truck looked like before i started the restore. It will be the same hight when it is finished. I am having the springs powder coated, it is suppost to make the ride smoother> I am powder coating for the looks not the ride.:p
the truck has 33 mudders and a 4" lift <block> when I am done it will have a 4" spring lift <no blocks>
Old 06-12-2003, 05:27 PM   #13
1967K10
That looks good! Do you think 35's would have cleared ok?
~Heath
Old 06-13-2003, 10:04 AM   #14
landon4421
Life is Good !
landon4421's Avatar
Have you looked at your truck lately? There is probally enought room for 44's with a 6" lift. I think with the 35's you should not have any problums. Mine would cut the tire when I went 4wheeling, but that was when I was jumping the truck and bouncing around on the rocks. Good luck Landon
Old 06-13-2003, 11:32 AM   #15
1969 GMC
1969 GMC's Avatar
don't mean to hijack your thread, but is that your scout II landon?
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 06-16-2003, 10:12 AM   #16
landon4421
Life is Good !
landon4421's Avatar
1969 GMC, No the scout II is my friend Rob's. Why do you ask?
