S.D.M.F.
In my girlfriends ford (yes a ford ugh
1969 Chevy Longhorn 396/400 3/4 ton. ![]() 1991 Chevy Camaro RS 305/700r4 ![]() 1978 Honda XL175 and XL350(the evil twin) ![]() 2006 Kawasaki ZX-14r drag bike-best e.t. 9.4@145 mph without nitrous 1971 BSA Thunderbolt 650cc ![]() Last edited by longhorn396; 12-08-2009 at 03:20 PM. |
![]() Join Date: Feb 2009
Re: Hey I need some help and u guys are good with that.?
9 times out of 10 the motor is going bad take it out and cheack the bearing in it put some wd-40 on the shaft that might help for a while until you can replace the fan motor
Brandon |
check the blower motor resistor. its behind the glove box. the motor plugs into it. should have two screws that hold it in. that what goes bad on the fords. a good parts store should have it.
get me more info on the car. year, motor, i will look it up for you...
S.D.M.F.
1996 ford contour. 2.0 4 cyl., automatic, regular gas. and i will check that too.
1969 Chevy Longhorn 396/400 3/4 ton. ![]() 1991 Chevy Camaro RS 305/700r4 ![]() 1978 Honda XL175 and XL350(the evil twin) ![]() 2006 Kawasaki ZX-14r drag bike-best e.t. 9.4@145 mph without nitrous 1971 BSA Thunderbolt 650cc ![]() |
S.D.M.F.
it somewhat works when u are going about 60 it will blow very little but hot air out of it.
if the resister was bad i dont think it would work at all I am pretty sure the brushes in the motor are worn out. the brush will move up and down when you hit a bump and the motor will start and stop working at diffrent times
Brandon |
S.D.M.F.
Is it one of these two?? or will either work. one is from napa. one is from autozone.
https://www.napaonline.com/Search/De...+50026+2026005 http://www.autozone.com/autozone/cat...dName=Duralast
1969 Chevy Longhorn 396/400 3/4 ton. ![]() 1991 Chevy Camaro RS 305/700r4 ![]() 1978 Honda XL175 and XL350(the evil twin) ![]() 2006 Kawasaki ZX-14r drag bike-best e.t. 9.4@145 mph without nitrous 1971 BSA Thunderbolt 650cc ![]() Last edited by longhorn396; 12-08-2009 at 03:25 PM. |
S.D.M.F.
well i can check both parts.
S.D.M.F.
heres the motor.
' http://www.autozone.com/autozone/cat...andName=Everco https://www.napaonline.com/Search/De...+50026+2026005
Robert Olson Transport
![]() Join Date: Oct 2002
its not the resistor usually when they go you get high and nothing else on the fan im betting its the motor or the wiring to it
S.D.M.F.
Ok. thanks guys
i appreciate the help
#13 |
~Rest In Peace~
i believe ford had problems with the fan motor caughing fire due to bad wiring and dry leaves in the cowl area
run tsb at the ford dealer see what they come up with
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
#14 |
its all about the +6 inches
the blowing @ 60 is not the fan, that's the fresh air ducting... ram air on the heater if you will. If you were to put it on recirculate (like max A/C) you'll get no aire flow at all.
Pull the dash trim, then the heater control panel, and look at the wires on the back of the switch. They are known for burning the connections there. |
#15 |
S.D.M.F.
im gonna check all of that when i get the dash apart and if thats whats wrong then im gonna take the heater fan back.
#16 |
S.D.M.F.
It was the blower motor thanks guys.
#17 |
Glad you got it figured out.
I had to throw the switch thing out there, it's an easy one to look at and see damage with your eyes... and common too. |
#18 |
![]() Join Date: Oct 2007
I had the same thing happen in my rig a few years back,,If I
would of checked in earlier I could of helped ya out .. glad you got it figured out though.. |
