Old 12-08-2009, 01:00 PM   #1
TwoFiftyShifter
'64 has no go?
My 64 GMC project is a pain to start and a hassle to move around the yard, mostly becuase when you hit the gas it dies, choke or no. You have to ease on the throttle for the rpms to rise. 230 L6. I had the carb off and rebuilt it even, didn't help the problem. Someone told me I was supposed to soak the accelerator pump in gas while doing that, but I didn't.... Could that really be the problem? I don't even see how it could be a vaccum leak theres only 1 vaccum line.... anyone else have any tips?
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 12-08-2009, 01:09 PM   #2
62gmc910
62gmc910's Avatar
Re: '64 has no go?
Did you check the float level when you had the carb apart , some of the internal passages may be plugged .was it soaked in carb cleaner at rebuid?
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 12-08-2009, 02:17 PM   #3
TheDark1
Intentionally Left Blank
TheDark1's Avatar
Re: '64 has no go?
Check for vacuum leaks at the carb base and at the intake to block gasket.
1965 C-10 Short Fleet 468/TKO 5-Speed
2004 2500HD Crew 496/Ally Blacked Out (SOLD!!)
1997 Formula WS6
2004 Jeep Wrangler (Sold)
2013 Jeep Wrangler (Sold)
2017 Jeep Wrangler (Blacked Out on 35's)
2011 GMC D-Max Dually Denali 3500HD (Sold)
2015 GMC D-Max Dually Denali 3500HD (Sold)
2018 GMC D-Max Dually Denali 3500HD (Sold)
2020 D-Max Dually Denali on 33x12.50's
1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles
TheDark1 is offline   Reply With Quote
