Old 12-08-2009, 04:19 PM   #1
southwilrise87
gauge cluster
How do you remove the stock gauge cluster out of a '65. Im removed all of the surrounding screws from the bezel and removed the light switch, ignition, etc., but I am still only able to get one side to pull out. I have completed all of the new wiring except for the gauges and I find it would be easier if I just removed them.
southwilrise87 is offline   Reply With Quote
Old 12-08-2009, 04:42 PM   #2
62gmc910
62gmc910's Avatar
Re: gauge cluster
you have to squeeze your arm up the back and undo the speedo and if its full guage the oil line
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 12-08-2009, 05:48 PM   #3
southwilrise87
Re: gauge cluster
I removed the speedo cable and the oil line. Ive felt up around the cluster behind the dash and I cant seem to find anything holding them in. Has anyone else experienced this problem? I supposed I could just splice the stock harness with the clip but im not sure which wires on the rebel harness correspond to the stock harness even with the labels.
Old 12-08-2009, 05:50 PM   #4
Byronic
The Beach Cruiser
Byronic's Avatar
Re: gauge cluster
I had to drop my steering column down a bit. I just loosened the bolts and it gave me room. Mine pulled from the bottom first.
1999 Silverado DD
1966 Panel Truck
2003 Harley Road Glide
1967 Schwinn Tandem Single Speed
Byronic is offline   Reply With Quote
Old 12-08-2009, 08:48 PM   #5
ol Curt
Junior Member
ol Curt's Avatar
Re: gauge cluster
x2 on the bottom first.
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline   Reply With Quote
Old 12-09-2009, 10:30 AM   #6
ChevySixty6
ChevySixty6's Avatar
Re: gauge cluster
If you have a manual choke, you need to reach up behind the cluster and undo the nut holding it to the dash. I always take off the headlight switch, but i don't know if it's required to remove the dash though. If you do, there's a button on the side of the switch that you push in as you pull the knob out.
Members i've met: LiLRed66
ChevySixty6 is offline   Reply With Quote
Old 12-10-2009, 10:40 AM   #7
ratskin
Re: gauge cluster
The cigarette lighter will hang up, as well.
ratskin is offline   Reply With Quote
Old 12-10-2009, 12:32 PM   #8
Muleman100
Muleman100's Avatar
Re: gauge cluster
Byronic, you are correct. I had to lower my steering column to get the guage cluster out. I replaced the face/glass. Had to lower it to get it back in.
Muleman100 is offline   Reply With Quote
Old 12-10-2009, 12:57 PM   #9
ol Curt
Junior Member
ol Curt's Avatar
Re: gauge cluster
You're right ratskin. I forgot about that one. The barrel on the back of the lighter threads off
