Old 12-09-2009, 04:20 PM   #1
ap2002
stock BB manifolds?
does anyone know if some stock manifolds from a 1969 chevelle with a 396c.i. fit on my 454BB in my 71 c10?
1971 C-10 SWB - LS swap w/4L60e, 20x8.5front 20x12rear,
1968 C-10 SWB - 454 BB TH350 -Gone!
ap2002 is offline   Reply With Quote
Old 12-09-2009, 04:28 PM   #2
suprachrgd82
Farmtruck desciple
suprachrgd82's Avatar
Re: stock BB manifolds?
Bolt patterns are identical, but head port size and shape may differ.
If I am not mistaken, 396 has D or oval ports, and the 454 has rectangular ports. Aftermaket haeds usually have rectangular ports that are larger.
What type of heads do you have?
suprachrgd82 is offline   Reply With Quote
Old 12-09-2009, 04:53 PM   #3
ap2002
Im thinking it has stock heads since the previous owner said he was running manifolds before he pulled the motor to paint the engine bay?
Old 12-10-2009, 01:25 PM   #4
suprachrgd82
Farmtruck desciple
Any more info on the motor/heads? Cart or truck motor? Year of production? Any casting numbers?
Truthfully, it would be pretty easy to pull the manifold and have a peek. Even pull the carb, if you can see down the plenums.
Post a pic, if possible, of the current heads and manifold.
Old 12-10-2009, 09:54 PM   #5
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
they would fit, but you might ebay the Chevelle ones and pick you up a set of whatever you want with the money. Chevelle correct dated stuff brings good money. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 12-11-2009, 12:34 AM   #6
ts71281
They will bolt up but the collector will point the wrong direction and you won't be able to hook pipes up to it. I have 2 sets of big block manifolds if you're interested in a set PM me You know me from PT.net so you know I'm trustworthY aka hirdlej
ts71281 is offline   Reply With Quote
