Old 12-09-2009, 08:36 PM   #1
tommyramone55
driveshaft hook up....help
Hey all,
need a lil help with my 1983 k30 4x4 350
when i got the truck the driveshaft was in the bed and the guy said it had a bad u-joint. Well I think it was a lie, dude told me u-joint was good shape. I need to know what I am missing.
I have the driveshaft but the shifter inside the truck just moves freely, do I hookup the driveshaft and it will fix that? I am pondering my mind and reading online but can't find what I am looking for. Any help would be great.
tommyramone55 is offline   Reply With Quote
Old 12-09-2009, 08:45 PM   #2
tommyramone55
Re: driveshaft hook up....help
and I have one more quick question i am sure yall could answer.
Is it safe to use a shackle on the front leafs?
Old 12-09-2009, 09:24 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Originally Posted by tommyramone55 View Post
and i have one more quick question i am sure yall could answer.
If you are talking about putting shackles up front -- NO
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 12-09-2009, 09:29 PM   #4
tommyramone55
10 4.
Thank you on clearing that up.
Old 12-09-2009, 09:34 PM   #5
tommyramone55
and i know im killing yall with all these other little questions, but one more. I wanted to body swap my 4 door k30 single axle. Think of anything besides the identical body that will mount to the frame?
Old 12-09-2009, 09:37 PM   #6
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Wait to your transfer case shifter just moves freely? Either your transfer case shifter is not hooked or something between the to things is broken! X2 no shackles up front!!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 12-09-2009, 10:59 PM   #7
tommyramone55
10 4.
Yeah like the shifter was rigged backwards with a bungee chord when i let it go it was just moving around.
Old 12-09-2009, 11:01 PM   #8
ghettoluxury
ghettoluxury's Avatar
whats wrong with the 4 door?
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 12-09-2009, 11:07 PM   #9
tommyramone55
all in all.
Needs some new seals nothing too major.
except for the fact its got rust, and the 4x4 needs to be hooked up/fixed? Idk I want to fix it.
Old 12-09-2009, 11:12 PM   #10
ghettoluxury
I wouldnt recomend it these crew cabs are gettin harder to find
Old 12-09-2009, 11:29 PM   #11
tommyramone55
i ment the 4x4.
good news i can feel it drop into the gear however when i bring it from 4wd hi to 2wd it clicks and stuff.
Old 12-10-2009, 12:19 AM   #12
tommyramone55
and any idea where I can get a body lift for my k30? for a good price?
Old 12-10-2009, 12:46 AM   #13
tommyramone55
I read where this guy did the b52 kit and used shackles on the front leafs just in the rear position.....
Old 12-10-2009, 06:28 AM   #14
84 400
Sb 400 club
84 400's Avatar
yeah these trucks came factory with shackles on the rea of the front springs. Alot of guys upgrade them for streanght. Offroad design makes a kit called HD shackles which are a 1/2 long and much thicker then stock..... However a shackle "lift" in the frint is not the best iddea. The b52 kit allows you to run your stock 52 inch rear springs in the front in place of your 3 leaf factory springs. This gains about 4 inch lift and allows for better flex then a lift spring. Your truck has 56 inch long rear springs if i remember right biut i beleave the kit has multiple holes to allow for the use of 56's
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
