12-09-2009, 09:37 PM | #1 |
Who makes this wheel?
This was posted on this site but the pic was copied from another site. I'm trying to get some specs on this truck, like 24xwhat? Backspace? What was done to tuck this wheel? What brand wheel? I've in deperate need on knowing how a 24x10 5.91bs wheel will tuck enough to lay pinch weld. I'll run something like a 275/25/24, or whatever may be on this black truck.
12-10-2009, 10:34 AM | #2 |
Re: Who makes this wheel?
The wheel doesn't matter, not really my style. I'd like to know where to find a buildon this truck though.
12-10-2009, 01:35 PM | #3 |
That truck has a PORTERBUILT DROPMEMBER on it so the front offset is going to be different than your truck. The DROPMEMBER narrows the front end width by I think 2 inches. Hope that helps. Also I believe the EASTWOOD company sells a product for finding out wheel offsets. You just bolt it on and adjust and it tells you what you need!
Tony from Norcal |
12-10-2009, 01:44 PM | #4 |
Here are a couple other pics of that truck. Those tire are 275-25-24. They also make a 255-25-24 if you need smaller.
Tony from Norcal |
12-10-2009, 03:18 PM | #5 |
That's a clean lookin' set-up.
12-10-2009, 05:02 PM | #6 |
THIS GUY HAS 22X10 ALL AROUND MAYBE YOU CAN CECK BS WITH HIM http://67-72chevytrucks.com/vboard/s...d.php?t=328041
70 SWB STEPSIDE 70 BLAZER 09 challenger |
12-10-2009, 06:17 PM | #7 |
That truck belongs to Chad. Another Board member on her Mr Tricky built the truck.
12-11-2009, 11:22 AM | #8 |
Thanks guys! I figured it was a DM truck, now I know. An awesome truck! I ordered in a 24x10 and we will make it fit.
Thanks for all the help. |
