Interior lights
I'm working on my interior lighting and I cannot find what I'm looking for.
I'm wanting to put some courtesy lights behind the front seats, in the side panels but I cannot seem to find much of a selection. I really want a small rectangular shape with an on-off switch .....but I can't find that. I want courtesy lights in the back......anyone done that already?
1972 Blazer - Bronco Orange - In the werks http://67-72chevytrucks.com/vboard/s...d.php?t=323444 1991 F250 - Hunting truck w/ Detroit rear locker, ARB front locker, front and rear winches .... and more.... 1997 Grand Cherokee - fun jeep - Detroit rear locker, ARB front locker, front winch, 411 gears, lots of lights ;-) 2004 Hot Rod DuraMax - Dnyo'd at the wheels with 525 HP and 1100 lbs torque.....mustang killer. |
SKINNY TIRES RULE!
Re: Interior lights
Have you checked JC Whittney or an RV supply company.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Re: Interior lights
JC Whitney didn't cross my mind...but worth looking I suppose.
I looked locally...NAPA, Checker Auto.....then here
Its lookin' like a Blazer!
Re: Interior lights
Maybe this place will have something for ya.
http://www.autoanything.com/lights/200A1221.aspx |
Re: Interior lights
How about a couple of 67-72 Chevy/GMC truck dome light assemblies? Easy to install and a perfect match. You could wire them to the existing dome light circuit.
I'm also trying to remember which dome lights had the switch built in with a rocker style lens. Volkswagen or Volvo or something like that. You could probably score a couple good ones at the "recycle" yard.
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod |
Re: Interior lights
I went to Lowes & found a LED bulb toolbox light. I put one above the review mirror & one in the back It is battery operated & has lasted 2 yrs with no problems. Actually gives off quiet a bit of light too. I zip-tied mine to the roll cage, but I think it came with some velcro or trim tape if you wanted to go that route for attaching it. They were around $15 each. I've seen these other round ones from Northern Tools that are about $10 ea. and they look to lay a little flatter.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
Rods
![]() Join Date: Nov 2002
Re: Interior lights
i used 66 chevy truck reverse lamps in the rear panels for int lights
Just keepin it simple. ![]() 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
Rods
Re: Interior lights
i know you said rectangle but this looked good and it kinda fit the look of the truck when i did it. I wired them into the stock lamp location so they work when the doors open and when i turn them on
Just keepin it simple. ![]() 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) Last edited by 70 Suburban; 12-11-2009 at 08:39 PM. |
Re: Interior lights
Those reverse lts look good, what did they set you back?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
Rods
Re: Interior lights
they were on my parts truck..
