12-10-2009, 10:35 AM | #1 |
Serpentine Setup
Ive seen a few trucks on here with a late model serpentine belt setup and also aftermarket billet set up and was wandering if some had it if they would post pics of theirs and list what type it was and how well it works. I am wanting one to hook my air and ps up to.
Thanks |
12-10-2009, 10:39 AM | #2 |
Under Construction
Re: Serpentine Setup
Heres some good reading:
http://67-72chevytrucks.com/vboard/s...d.php?t=233335 I used a serpentine setup from a '94 chevy suburban, the truck is the same as well. you can see pics of it in my build thread. Good Luck!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
12-10-2009, 01:11 PM | #3 |
i dont have any pics handy but my serp set up is off of a 4.3 from the junkyard. Just get everything off the front of the motor including the water pump and powersteering pump it is very simple.
*SOLD* 1968 Chevy SWB Fleet 350/350 combo Tach/tilt/buddy buckets Bagged/18" Wheels Black on Black Project "Pandemic" the Farm Rat 1927 Chevy Capitol Truck Rat rod '30 Model A Frame Dual Carb 5.3 LS http://www.67-72chevytrucks.com/vboa...d.php?t=804162 2007 GMC 4 DOOR 2WD BUILT 5.3 STAGE 3 CAM 93 TUNE LIFTED 22X12 WHEELS 33" TIRES 2023 Jeep RENEGADE Wifes ride |
12-10-2009, 03:01 PM | #4 |
March pulley and bracket set,,,,super happy with it...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
12-10-2009, 05:22 PM | #5 |
I had mine given to me by my Dad. I came off of a 1995 Chevy 1500 and works great. I just had to buy the water pump (reverse rotation). I also included my cheap fan setup using fans from a Ford Taurus (Ford, I know) and some sheet metal for the shroud. The Taurus fans are cheap and plentiful.
12-10-2009, 05:26 PM | #6 |
Frequent Flyer
We converted my Dads 76 over to a serpentine setup off of a 92. I think hardest part on it was getting the A/C lines and stuff switched around to fit.
12-10-2009, 05:26 PM | #7 |
Why did I post pics after big_al_71, mine really looks like a bag of ass! I will have to hit it with a few cans of spray paint. It really does work though.
12-10-2009, 05:28 PM | #8 |
That's right, it's Copper!!
Mine is a March system as well.
Tom: 1968 Chevy SWB ZZ383 W/700R4 Gen-II Compact Vintage Air System PPG paint, Mandarin Copper and Vanilla Shake. http://www.hubgarage.com/mygarage/fastom Stupid should hurt and eventually become fatal! Last edited by fastom; 12-10-2009 at 05:29 PM. |
12-10-2009, 05:43 PM | #9 |
thats funny!!!! hey man dont sweat it I feel the same way when I see some other guys trucks in here.....then I look at my bucket
12-10-2009, 05:50 PM | #10 | |
Under Construction
SHOW OFF!!!
12-10-2009, 05:57 PM | #11 | |
Frequent Flyer
That what I thought about after posting the set up we did on my dads also Last edited by JWall; 12-10-2009 at 05:58 PM. |
12-10-2009, 06:11 PM | #12 |
Here's mine....Concept One.
4,000 miles and no problems except I studded the mounting points on the heads cuz I had a bolt shear off. http://c1pulleys.com/
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
12-10-2009, 06:12 PM | #13 |
let me dig a pic up of my hoopty!!!! HAHAHAHA
12-10-2009, 06:19 PM | #14 |
I'M TRUCK CRAZY!
What do you get the reverse water pump off of?
I can't remember for sure what year I have, but I have the driver side of a serp setup with the power steering pump. I think it is from a 99 truck. It was my buddy's truck. He rolled it a long time ago. Last edited by LOW DOUGH; 12-10-2009 at 06:19 PM. |
12-10-2009, 06:29 PM | #15 |
12-10-2009, 06:32 PM | #16 |
SactoJim and FastTom now those are serious machines!!!!
Mine is a bucket in comparison...
12-10-2009, 06:32 PM | #17 |
If you have that sorta cash they sure do look nice agreed. Mine came off a 93 Chevy 5.7. Removed the upper tension pully and had it powder coated with silver. Since I wasn't installing A/C I used a A/C delete pulley. And added twin Virgo Fans. Don't forget to get the upper and lower rad hoses. Especially the upper hose, in my case it was a bit longer over stock to reach the radiator. For the power steering pump swap your fitting out with your old pump fitting and that will save you from getting new line.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
12-10-2009, 06:42 PM | #18 |
I have seen two styles even on the 5.7 L engines. One is a two piece made of a cast. These are most common. The one I used was a one piece metal. The only draw back to the one piece is that to remove it requires removal of the water pump at it sits behind the water pump.
12-10-2009, 07:01 PM | #19 |
For my water pump I just told the computer jockeys at advance auto that it was for a 1995 chevy 1500 with a 5.7. Then I had to tell them tire size, trans type, if it had disc brakes, etc...etc...etc.
12-10-2009, 08:27 PM | #20 |
Never Ending Projects
I pulled all of this off a '94 S10 Blazer with the 4.3L engine. Everything bolts on and lines up but there is one hole missing on the pass. side head, if you are using pre '88 head (IIRV).
I figured out where I needed the hole, made a jig, drilled and tapped it. Worked perfect. Now I just need to finish cleaning all the brackets and engine up. I also order a A/C delete pulley since I won't have A/C right away. It replaced the A/C compressor with an idler pulley.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... Last edited by chevy_mike; 12-10-2009 at 08:28 PM. |
12-10-2009, 09:50 PM | #21 | |
I am thinking of using a set up off a 97 Vortec truck for my 72, even though the alt. is on the pass side and AC compressor is on the driver side unlike original, as the compressor is the more efficient Delphi Last edited by WIDESIDE72; 12-11-2009 at 10:32 AM. |
12-11-2009, 12:58 AM | #22 |
It is a nice setup to change over too.
1970 Chevy K10 350 CID with 4 speed 4" lift with 86 Dana 44 Front disk brakes Electric fan/Internal regulated Alt. |
12-11-2009, 01:09 AM | #23 |
I guess I fail to see the advantage. Seems like a much more intricate setup than the trusty old v-belt and pulleys
12-11-2009, 08:02 AM | #24 |
blood type; Retumbo
12-11-2009, 10:27 AM | #25 |
Comment about the advantages. I think besides the obvious cleaner updated look are that it saves you time getting all the stock pulleys and harder to find brackets with a trustworthy system without spending a fortune and your time to do so. And by doing this and adding the electric fans will increase gas mileage to a slight degree.
