Old 12-10-2009, 04:30 PM   #1
DT1
DT1's Avatar
Who makes a good coil spring compressor?
I'm gearing up to rebuild the front suspension on my C-10.
I need a source for a reliable/safe coil spring compressor.
I've searched and most that I see look pretty chincy. Anyone know of a good one?
DT1 is offline   Reply With Quote
Old 12-10-2009, 04:48 PM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Who makes a good coil spring compressor?
you can do it with out one its realy easy and just as safe....
jack up the truck place it on stands...remove wheels and discs...then you can place the floor jack under the lower A arm loosen up the upper and lower control arm castle nuts.. strike the spindle along side the taper of the ball joint it will pop loose then jack up slightly remove the castle nuts and lower jack slowly.till it rests on the stands then release the tension from the spring...the rest is just a bunch of tie rod ends you could use a picle fork that you can get from any parts store..they even have them to lend
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 12-10-2009, 05:15 PM   #3
hayhauler71
hayhauler71's Avatar
Never needed one on truck springs just on the cars.
hayhauler71 is offline   Reply With Quote
Old 12-10-2009, 05:28 PM   #4
mclairmo
I got my inside style compressor from Harbor Freight for cheap and it works fine. Use a chain, too.
mclairmo is offline   Reply With Quote
Old 12-10-2009, 05:53 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Hottrucks has the plan but put a chain thru the spring and control arms and put a bolt and nut on it.If the spring jumps you can just watch it stay in place.There is a video on here somewhere on doing a spindle swap.Taped by seeten and the "Worthless" gang.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-10-2009, 07:30 PM   #6
DT1
DT1's Avatar
Right after I posted I realized that I could do it without it also.
Old 12-11-2009, 01:13 AM   #7
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
You can borrow it from Advance, autozone or any other parts store with a rent a tool program.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 12-11-2009, 01:20 AM   #8
67ChevyRedneck
67ChevyRedneck's Avatar
This is what I did. My truck didn't have a motor, trans, or hood when I rebuilt my front end and I was afraid there wasn't enough weight to hold the nose down as I popped the spring free.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-11-2009, 01:48 AM   #9
CUSTOM_1O
HaV0KSR559<~~~
CUSTOM_1O's Avatar
Ya thank god we dnt need them compressors half of em suck ne ways
...1969_CUSTOM_1O
FLEETSIDE_LONGBED
V8_THREE-FIFTY
[COMPLETE-EDELBROCK]
[PERFORMANCE-SERIES]
[CAM_CARB_MANIFOLD]
...TURBO-400_TRANNY...
CUSTOM_1O is offline   Reply With Quote
