Old 12-10-2009, 05:41 PM   #1
3beanlimit
Update Steering
Hello everyone,
I have a 70 c10 and I would like to update the steering to a tilt column with power steering. I currently do not have power steering. It seems like people update there column with a tilt column from a van. What years of van can I get this from? Or is someone has a alternate route please chime in.
3beanlimit is offline   Reply With Quote
Old 12-10-2009, 05:45 PM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Update Steering
Van tilts have to be modified to fit. 70's-early 80's, before keys were added to the column do a search on the site and you will have plenty of reading material. As far as power steering, you could become a member for 25.00 a year and post a want to buy ad, asking for the ps box, pump, and hoses needed to do the conversion.
best of luck!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 12-10-2009, 09:08 PM   #3
sweet70beast
sweet70beast's Avatar
Re: Update Steering
My tilt came out of an 82 Van. Vans with the round headlights have the right style columns but don't pass by the square headlight Vans without looking because this 82 Van had the square ones.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 12-25-2009, 10:49 PM   #4
70 aquamarine
70 aquamarine's Avatar
Re: Update Steering
any one ever put a 73-87 chevy pickup steering column in a 67-72 chevy truc ?
70 aquamarine is offline   Reply With Quote
Old 12-26-2009, 01:37 AM   #5
1968CHEVYC10
1968CHEVYC10's Avatar
Re: Update Steering
[QUOTE=70 aquamarine;3693362]any one ever put a 73-87 chevy pickup steering column in a 67-72 chevy truc ?[/QUOT
I think these had the column mounted ignition switch, but you could probably do it.
'68 C10 LWB 6.2NA/NP833 3.73's
1968CHEVYC10 is offline   Reply With Quote
Old 12-26-2009, 01:50 AM   #6
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Re: Update Steering
Originally Posted by 3beanlimit View Post
Hello everyone,
It's interesting that you have a 70 because that was the first year that the tilt column was available. You could scrounge the wrecking yards for a 70-72 tilt column and pick up the power steering stuff at the same time or you could also buy an aftermarket one from a supplier like LMC Truck but they are very pricey.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 12-26-2009, 07:43 PM   #7
70 aquamarine
Re: Update Steering
what about any ever put a 73-87 dash in a 67-72 chevy pickup ?
Old 12-26-2009, 08:03 PM   #8
threeonthetree
threeonthetree's Avatar
Re: Update Steering
is 4wd power steering the same?
I have a 4wd blazer with power steering and i kinda wanna snag it.
and my uncle has a tilt column from a 83 would that work?
sorry to jack your thread just ?s i always wondered.
that wouldn't be worth starting a new thread.
Smoking Tires Since 1992
1969 c10 AKA SIN
1985 SSWB TRAZER
(super short wheel base)
threeonthetree is offline   Reply With Quote
Old 12-26-2009, 08:08 PM   #9
70 aquamarine
Re: Update Steering
well i have put a 80 chevy dash and steering column in my 69 but havent figured out how to hold the steering column up in the right place on the fire wall. you have to modifie your brake assembly where your steering column goes because they are bigger and longer then where it comes through your gauge cluster you have to make that bigger to
Old 12-26-2009, 08:09 PM   #10
70 aquamarine
Re: Update Steering
but if you do those things it would work and also your wiring
Old 12-26-2009, 08:26 PM   #11
threeonthetree
Re: Update Steering
sounds like to much work haha.
ill keep it like it is with a big wheel.
1969 c10 AKA SIN
1985 SSWB TRAZER
