Old 12-10-2009, 07:05 PM   #1
rsavage
rsavage's Avatar
Did I make a mistake?
I had a 4speed in my burb which I pullled. Today I bolted up the 200 4r. As I was seeing how the auto crossmember was going to fit, I realized that I hadn't taken the pilot bushing out. Is that going to be a problem? The converter bolted up to the flexplate but I don't know if I am putting a bunch of pressure on the nose of the converter. Anyone have the answer?
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 12-10-2009, 08:13 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Did I make a mistake?
Probably not but losen the bolts with an eye on the flex plate and see if it moves back toward the motor or there is more than a few threads of tension on the bolt
dwcsr is offline   Reply With Quote
Old 12-10-2009, 08:18 PM   #3
The bushing needs to come out.I can never get the 3rd bolt in the fle plate when I leave the bushing in.
Old 12-10-2009, 08:51 PM   #4
sweet70beast
sweet70beast's Avatar
If you leave it in, over time it will prematurely take out the thrust bearing for the crankshaft. The snout of the TC fits into the same hole and will put pressure on the thrust bearing.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 12-10-2009, 09:27 PM   #5
rsavage
rsavage's Avatar
Guess I'll be pulling it back out tomorrow. I'm getting a little too old to do stuff twice. I'll be kicking myself in the a$$ tomorrow.
1961 C1 Corvette
2021 Durango RT 5.7
