Old 12-10-2009, 07:07 PM   #1
snowblind
snowblind's Avatar
Major headlight upgrade for GMC trucks
Hi everybody.
I thought I would toss this out there for anyone who is interested in upgrading the headlights in their GMC.
I am having a custom wiring harness made that will allow me to run 4 x low/high beam headlights instead of the stock 2 x low/highs and 2 x high only. Installation involves NO CUTTING of the stock wiring. The new harness is custom made to accept the old headlight connectors as the turn on signal for the new relays. Headlight power will now go directly from the alt/battery with minimal current going through the stock headlight switch.
My harness is being made by Susquehanna Motorsports http://www.rallylights.com/ They specialize in rally and race car lighting and use only Hella relays and connectors. I was quoted $130 for one harness. Obviously the price will go down the more harnesses I order.
It would definitely be less expensive to buy the relays separately and wire it all yourself but this will be a slick harness and leave the stock wiring untouched.
Shoot me a PM if anyone is interested in ordering with me.
Matt
Matt
'72 Jimmy Build
snowblind is offline   Reply With Quote
Old 12-10-2009, 07:13 PM   #2
cdowns
cdowns's Avatar
Re: Major headlight upgrade for GMC trucks
you may run into police problems on the road
Old 12-10-2009, 07:24 PM   #3
snowblind
snowblind's Avatar
****Off-hwy use only of course****
To avoid bothering other off-hwy drivers I plan to aim one set as low as possible and the other set just a teeny bit higher. I'm not looking to blind anyone I just need more low beam light. I rarely use high-beams.
Is there a DOT law specifically against 4 low beam headlights? I feel like I see people running like that all the time...
Matt
'72 Jimmy Build
Old 12-10-2009, 07:26 PM   #4
69GMCLonghorn
69GMCLonghorn's Avatar
From what I understand, you can have 4 headlights on as long as they are not on high beam. I did a similar conversion on my '95 Chevy truck, but kind of backwards... When you hit the high beams, the low beams turned off. The relay setup that I bought for that, allowed all 4 lights to stay on when the high beams came on, but didn't allow for 4 lights on low beam due to the high beam lights not being 2 stage...
69GMCLonghorn is offline   Reply With Quote
Old 12-10-2009, 07:34 PM   #5
snowblind
snowblind's Avatar
Isn't the stock set up 4 x high beam and then 2 x on low beam? That's how my Jimmy is and the wiring looks unmolested?
Matt
'72 Jimmy Build
Old 12-10-2009, 08:22 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
4 high and 2 low.
I'd bet a kick in the pills that 4 low would not be legal... almost positive.
Just adjusting them alone will do wonders, and then relays and normal haligon sealed beams (I recomend sylvania's silver star) and you will be seeing everything.
Old 12-10-2009, 08:57 PM   #7
byrd
Union Electrician
byrd's Avatar
Originally Posted by snowblind View Post
Hi everybody.
Matt
Using standard 12 volt auotmotive relays(they sell for around $5-6 bucks/each at Radioshack), and an intenally regulated alt will make a HUGE difference. I will venture to say the candle power was 3-4 times as what it was with the stock set up. There is no need for 4 low beams and I, like longhornman suspect you will have problems with po-po.
BTW LMC sells(others do too just was easier to link to) the premade harness with no splicing for the GMC truck and it is only $30. Get you a internally reg alt conversion and a new alt and you are still out less than the $130 you were quoted and will be legal, and just as bright.
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=74
I have used the harness(took it out as I didn't need it) and found that if you would spend some time making sure all your grounds are excellent and you swap to an internal reg alt, that you really do not need the harness...... jmho...Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 12-10-2009, 11:31 PM   #8
Longhorn Man
Randy, you pointed out something I usually mention, but failed to this time.
Clean the grounds on the core support.
Old 12-11-2009, 08:52 AM   #9
mrein3
mrein3's Avatar
Originally Posted by byrd View Post
Using standard 12 volt auotmotive relays(they sell for around $5-6 buack/each at Radioshack), and an intenally regulated alt will make a HUGE difference. I will venture to say the candle power was 3-4 times as what it was with the stock set up. There is no need for 4 low beams and I, like longhornman suspect you will have problems with po-po.
I will disagree with one thing above. You do need to do the relay harness. Without it the factory wiring runs too much current through too small a wire when you turn on your headlights - high beam or low beam. By putting the relays in you are no longer pulling current through over 20 feet of 16 gauge wire to run your headlights. I'm not sure about the linked harness but a decent one will run a 12 or 10 gauge wire from the battery to each relay, then from the hot when energized leg of the relay right to the headlight.
In stock form on my truck I measured 10.5 volts at the headlight. Through relays you're at full battery voltage which is 12 to 14.5 volts (or more if your stock voltage regulator is out of whack. )
All that current drop in the stock wiring produces heat. Heat kills the contacts in your headlight switch.
I wish that pre-made LMC harness was available when I rolled my own harness. I don't have $30 into my setup but time is money. That $30 LMC kit appears to have both relays included which like byrd points out are about $5 each. So you're really only paying $20 for the harness.
As others have pointed out:
1. Do the relay upgrade. (No more burning out your headlight switch)
2. Install halogen sealed beams. (50 state street legal)
3. Adjust your headlights.
Disclaimer: I don't work for or have any financial interest in LMC.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 12-11-2009, 02:47 PM   #10
snowblind
snowblind's Avatar
Thanks for all the great input guys. I have a 100 amp 1 wire alternator and I will be running Hella "E-code" headlamps with replaceable 55w/65w bulbs.
The reason I want the four lows is because I regularly drive a dark and windy mountain road that is strewn with rocks and boulders. It's usually snowing and the road has regular traffic coming the other way so high beams really aren't an option. In my previous vehicle I ran a pair of the Hella Euro H4 headlights and a set of Micro DE fog lights. The combo was bright and I really liked the sharp cut-off but I still felt the need for more total light.
I don't really want to mount axillary lights on the grill of the Jimmy so I saw this as a decent alternative. Since this harness would be custom I'm thinking I may go one step further and wire the second set of lows on a separate relay. Then I could use a toggle switch to independently turn on the second set of lows.
Thanks for the heads up on the LMC harness. Looking at that link the GMC headlights they sell actually all ship with low/high bulbs but have a wiring adapter that leaves the lows off in the second set!!! If I wasn't going for 4 lows I would probably use that harness and save some money but for me it's really a choice between 4 upgraded lows or 2 upgraded lows PLUS a set of auxiliary lights.
Matt
'72 Jimmy Build
Old 12-11-2009, 05:02 PM   #11
JJanzen
JJanzen's Avatar
Byrd,
On the LMC harness upgrade, does that run from the external regulator or does it originate from somewhere else. I am just getting to that point on my build and don't yet fully understand the headlight/engine compartment harness/setup. Thanks for the help.
Joel
Blue72
Red72
JJanzen is offline   Reply With Quote
Old 12-11-2009, 09:18 PM   #12
byrd
Union Electrician
byrd's Avatar
Originally Posted by JJanzen View Post
Byrd,
Joel
The harness directly connects to your battery and plugs into your existing headlight connector and it all works by plug and play. The only part you have to physically connect is to the battery.
You might want to pull the battery out to install the realys behind it on the core support to conceal them, other than that is should take about 15-30 minutes to install the whole set up depending on how much time you spend trying to hide the harness.
Zip:40272
Old 12-14-2009, 06:55 PM   #13
snowblind
snowblind's Avatar
Hey Everybody.
I wanted to share these photos from yesterday. I discovered another drawback of the stock low beam set up. Snow and ice build up on the high beam when not in use making it pretty much useless when you do need it.
Matt
'72 Jimmy Build
Old 12-14-2009, 08:01 PM   #14
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Hey.... is that hood cracked open??
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 12-14-2009, 09:20 PM   #15
mrein3
mrein3's Avatar
Hey Everybody.
pictures snipped
Proving once again that two headlights are better than 4.
JK.
The global warmers out there are right now discovering that all those LED stoplights they installed to save our mother the earth don't melt snow either and now folks are crashing into each other at intersections
http://wcco.com/wireapnewswi/High.ef...2.1363896.html
You can't make this stuff up fast enough.
'72 Malibu hard top
Center City, MN
Old 12-14-2009, 09:26 PM   #16
Thealien
Thealien's Avatar
I am an electrician and recently took a course on traffic controls and that was discussed. The LEDs use 1/10 the electricity but they have to send techs out to clean the snow off
Old 12-14-2009, 09:40 PM   #17
snowblind
snowblind's Avatar
I actually have the piece to go in there but it's riveted to another grill and I haven't got around to drilling it out yet.
Matt
'72 Jimmy Build
Old 12-14-2009, 09:49 PM   #18
snowblind
snowblind's Avatar
I can't understand how light bulbs got SOOOOO much attention as a way to save power. Heating water was, is and will probably always be the #1 energy use by most consumers (other than driving of course). I have a thermostatically controlled "cool" water washing machine that saves hundreds of dollars per year over washers that dump hot water in regardless of actual water temperature but I've never heard word one about this technology in the press or government literature.
I'm actually all for the environmentalists even when they go off a little half-baked but I gotta think that the CF bulb manufactures have been spending some serious lobbying dollars to get everyone so worked up about light bulbs. How much does a 90% increase in light bulb efficiency add up to?
Matt
'72 Jimmy Build
Old 12-14-2009, 11:06 PM   #19
mrein3
mrein3's Avatar
Its all about unintended consequences. When the global warmers report a 90% savings in energy cost, do they add in the cost of the truck, the fuel for the truck, and the workers in the truck dusting off the stop lights? AND the cost of the bent fenders? NO. The bent fenders are passed off to the rest of us in the form of higher insurance rates. The cost of brushing off lights is passed off to us in the form of higher taxes. Neither of which the working stiffs like me in this country need right now.
The compact fluorescent (CF) light bulbs - did you know they contain mercury? When they burn out you are supposed to recycle them. How many prius driving, prematurely gray, sandle wearing CF users actually pay the money to drop them off at the recycler? What happens 50 years from now when all the landfills that are full of CF bulbs will need to be part of some superfund clean up?
What were we talking about again? Oh yes. Snow on headlights. What I've found is that when it is snowing hard enough to fill up your headlights like that you're better off driving with low beams anyways. The light from your high beams really reflects off the falling snow.
'72 Malibu hard top
Center City, MN
Old 12-14-2009, 11:51 PM   #20
Andy4639
Old member
Andy4639's Avatar
I bought two relays and wire had about 1 hr of install time. The differance is well worth the time. The relays were mounted on the drivers side of radator and hot wire ran over to battery. Jumped the hot from one relay to the other and then to both head lights. I also have my driving lights running off the low beam relay. This has them cut off when I hit the high beams.
Simple schematic of the relays.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-15-2009, 01:36 AM   #21
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I recently heard (or read) that the actual amount of mercury is about the same as the size of a ball-point pen tip. Still, if you add up enough millions of them...
And I'll have you know I was prematurely gray a long time ago! No Prius or sandals though....
- Mike -
RIP El Jay
Old 12-16-2009, 06:19 PM   #22
snowblind
snowblind's Avatar
It is better to use low beams in heavy snow and sometimes even fog lights and parking lights with no headlights at all.
An additional factor in my wanting four low beams is the option to have the outer pair aimed as low as possible and use them alone when reflections are a problem. In better conditions I could use all four low beams with the middle lights aimed a bit further up the road. The high beams would see very little use most of the time.
Matt
'72 Jimmy Build
Old 12-20-2009, 04:37 PM   #23
C-10 simplex
RE: the 4 vs. 2 headlight debate:
http://www.adclassix.com/a3/67gmcpickuptruck.html
i was talking to some heavy-duty truck mechanics about this and i hear that on 2 light setups the single light's hi-beam setting is higher than the hi beam lights on a 4 light setup?
At any rate, i like to looks of the gmc better than chevy.
C-10 simplex is offline   Reply With Quote
Old 12-20-2009, 05:38 PM   #24
Longhorn Man
you can aim them higher if you want, any direction you feel the need to aim them.
Old 12-20-2009, 05:53 PM   #25
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Aimed higher? Does not make sense... high beams are (or should be) aimed optimally, regardless. However, it may have longer reach.
A lamp that serves as both high and low beams will be somewhat compromised on both beam settings. So on a quad setup, the high-only lamps can be optimized since the bulbs/reflectors/lenses do not need to throw a low beam pattern. But there is also a downside -- all else being equal, a smaller lamp will throw less light than a larger lamp, simply because its reflector (& lens) has less surface area. What this means is that on low beam, 5 3/4" lamps do not have as much light output as 7" lamps on low beam. On high beam, the quad lamps compensate for their smaller size by having all four lamps lighting the road.
To me, the ideal setup would be 7" high/low E-codes plus an inboard pair of 5 3/4" E-code high beams.
- Mike -
RIP El Jay
