05-22-2002, 04:54 PM | #1 |
Vent window rubber? HELP!!!!
Ok, I got all the new rubber and channel for the vent windows on my 67. I even bought new hardware from LMC to install them as there appears to be some form of special rivets holding things in place. Well, In the pack of rivets there is a little tool that looks like a center punch of sorts. How am I suposed to attach these things? A pop rivet tool will not work on them. Any help is welcome. Thanks!
05-22-2002, 05:52 PM | #2 |
What a coincidence, I am having, or rather, have just had the same problem except I bought my seals from Chevy Duty. Anyway, when I find an excuse to buy a new tool I do it. I purchased a $13 pop rivet tool and purchased a couple packages a varying length 1/8" diameter pop rivets. They are fun to use a work well. By the way, how do you put the window and vent window back in. Its been a pain, neither want to go back in easy. Thanks, -Tim
05-22-2002, 05:53 PM | #3 |
I had the same problem with rebuilding my vent windows. I ended up putting the flat side of the rivets on a hard surface, then placing the "punch" looking thing on the other side of the rivet, and using a hammer to flatten that end. It worked pretty good besides a few that i couldnt get the punch very straight on.
68 long fleetside 67 camaro 83 monte carlo 88 SS monte carlo |
05-22-2002, 06:03 PM | #4 |
I have been looking at it, and thinking maybe a large C clamp used to cruch down the rivet heads may work. I dont know. I am thinking about farming this job out so I have someone to scream at if they still whistle! :0
05-22-2002, 06:33 PM | #5 |
You use the tool (punch) to spread the rivet it rolls the hollow end over, when you drill out the old rivet dont make the hole any bigger. You should have got special rivets for the window henge. Make sure that you paint the frame be for you assemble.
1969 GMC S/B S/S 3" drop |
05-22-2002, 06:38 PM | #6 |
hold a bigger hammer on the backside of the rivet. put the tool(cant think of the correct name right now) on the other side of the rivet and hit it with a bigger hammer. its not that hard. good luck, Ben
------------------ Brandon, SD 69 GMC 1/2 ton 2wd wide long bed with wood 3 on the tree 350 engine 4 bolt main rv cam AIM = Alphray04
Brandon, SD 69 GMC 1/2 ton 2wd wide long bed with wood 3 on the tree 350 engine 4 bolt main rv cam AIM = Alphray04 |
05-22-2002, 06:40 PM | #7 |
I haven't "been there - done that" yet, but I'm about to.
Would it work to put the assembly in a vise with the tool behind the rivet and then tighten down the vise? |
05-22-2002, 08:49 PM | #8 |
I cheated! I bought new vent window assemblys from Kingparts.
------------------ 67 GMC Stepside(UNDER CONSTRUCTION) 67 GMC Custom 67 Chevy C-30 |
05-22-2002, 09:17 PM | #9 |
Now the others dig........
how much did those window assemblies cost?
And for those of you that have painted the bars and the frame of the vent window, what paint do you recomend and how would you go about doing so. Thanks -Roger ------------------ IN A TUX WITH A 68 BOWTIE. *SELLING FOR PARTS* "P.O.S" Stepside 68, Primed from Fl., rusted out a bit, but *SELLING FOR PARTS* Interested? E-mail me!! "Rusty" Stepside 68 Brown/Black (not by choice, soon to be charcoal grey) This is my baby, just put in wood bed. Overhauled 307. Just needs the brakes to be redone then its ready to run. Oh yeah, My girlfreind's got a 63 named "Blue Boy"
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
05-23-2002, 08:07 PM | #10 |
The way mine were done we used a ratchet handle in a vise and the tool and a hammer.
I did't like the way mine came out so I bought new ones from Rick's for $129.00 each. The quality of the ones I got suck. ------------------ 1969 GMC S/B S/S 3" drop
