Old 12-11-2009, 12:35 AM   #1
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Nitrogen for bags question
Hey suspension gurus! My buddy is picking up a truck this weekend that is bagged and is fed by compressed nitrogen. Is there anything that he should be aware of about running nitrogen? The truck will be his DD, so I am trying to figure out what I can for him about it. Also, what is an empty, extra tank worth? The guy selling the truck has an extra tank that he will sell him for $45. Is that worth picking up with the truck?
Thanks in advanced for any help guys.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 12-11-2009, 12:46 AM   #2
texastrendz
Re: Nitrogen for bags question
your gonna get mixed views on the use of nitrogen.
negatives: it cost money, air is free. tanks are big and take up room in the bed. you run out of air, you are stuck.
postives: no water in your system, can easily adjust how fast you want your truck to lift. that means super fast or really slow by dialing the regulator. no compressors needed.
i run both, i have nitrogen for normal use. i also wire in a compressor just in case i get crazy and run out of air. just put a tee in and use a pressure switch. i always run a 5 gallon tank even with my nitrogen bottles so i can run a compressor also.
texastrendz is offline   Reply With Quote
Old 12-11-2009, 01:06 AM   #3
Driveway Dreams
I have car A.D.D.
Cool. Thanks for that info. What is a "normal sized" nitrogen tank cost to fill? I say "normal sized" because I do not know what size the tanks are.
-Gerald
Old 12-11-2009, 10:10 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Contact your local gas supplier to find out the value of the bottle and the cost to refill.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-11-2009, 02:21 PM   #5
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I think he would be better off putting his $45 twoards a compressor.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 12-11-2009, 02:56 PM   #6
redsled04
redsled04's Avatar
those tanks sell for like 150-300 depending how big.There 10-20 dollars to fill up.I like having an extra just incase you run out.Ive ran out before.at low psi they dont lift so well.
redsled04 is offline   Reply With Quote
Old 12-11-2009, 03:01 PM   #7
redsled04
redsled04's Avatar
I ran one for daily driving and it would last a week but I could only rais up to leave work or leave for work.Nitro is fun if you want to get off the ground or hit a lot of switches compressors wont keep up.
Old 12-11-2009, 05:09 PM   #8
shortbed70
shortbed70's Avatar
nitrogen is faster than air because you can run more pressure but it cost to fll and having a huge tank in the bed with a valve hanging on it. Better check with your local dot to see if thats legal in your area.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 12-11-2009, 10:40 PM   #9
texastrendz
nitrogen is fun as hell at the stop lights, really fun when the guy next to you only has a compressor.
Old 12-12-2009, 01:23 PM   #10
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
I have built/run both systems. I generally tell my guys running Nitrogen that it is for off road show only vehicles since here in MT it is a $10,000 fine for and uncapped tank in a moving vehicle. Also have a friend that rather than build a truck he bought a Toyota off fleabay with a BIG nitogen bottle in the bed just inside the tailgate. It's like 8" diameter and runs the entire width of the bed. Filled it's like 2000+ PSI. I can't imagine the horror if that sucker ever got rear ended by something big enough to tear the valve off the tank.
The nicer systems I have done usually use smaller on board nitrogen as a back up with electric or EDC compressors for daily. For my own rig I plan to use an Idea from a customer rig. The guy was big into racing for a long time and had these electric bottle openers generally used for Nitrous. We set the car up with two scuba tanks filled with nitrogen with the openers on and a 5 gal tank fed off two Viair 450's. The bottle openers allowed him to seal the Nitrogen to save waste and generally ran off the viairs. If it needed a quick fill or flex on a stoplight player a simple flick of the switch and plenty of Nitrogen. They just install in place of the "faucet" handle on the tank.
Josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 12-12-2009, 01:32 PM   #11
texastrendz
this is my setup
Old 12-12-2009, 04:30 PM   #12
LMDGUY
LMDGUY's Avatar
my friend has nitrogen on The Texas Outlaw (check th new Street Trucks Mag).. it kinda nice cause if u dont drive it very often and the system is empty you just cracks open the valve and the tank is full. then the compressor take over from there
1973 C10 "Chain Reaction"
Street Trucks cover Feb 2012
2013 Silverado
1964 Cadillac
LMDGUY is offline   Reply With Quote
Old 12-12-2009, 05:46 PM   #13
project 67 sub
project 67 sub's Avatar
Originally Posted by texastrendz View Post
this is my setup
got any videos of your truck in action?
project 67 sub is offline   Reply With Quote
Old 12-12-2009, 07:17 PM   #14
texastrendz
nah, i actually wrecked it not long after i finished it. the roads here in houston suck. i hung it up on a man hole sticking out of the ground about three inches. it caught the lower control arm. i did have it set to about 400 psi one time and hit it. thing popped up like toast. it was cool, but the truck would not survive, the frames on these trucks are to weak for that.
Old 12-13-2009, 01:43 AM   #15
ShowSS12
ShowSS12's Avatar
Hey on the nitrogen tanks do they refill the bottle you have or are they exchanged like welding tanks are? I would like to paint a tank to match my truck but it would sux if i had to exchange it.
Adam M
STX Designs
Motorcycles | Choppers | Hotrods
ShowSS12 is offline   Reply With Quote
Old 12-13-2009, 03:40 PM   #16
texastrendz
i think it matters if you own the bottle or lease the bottle. i own my four bottles. they fill them at twsco. texas welders supply co. about 10 dollars to fill them. i get about 45 lifts out of each one. that is completely down to way above ride height.
Old 12-14-2009, 06:37 PM   #17
LMDGUY
LMDGUY's Avatar
Ya they will refill yours if you own it.
2013 Silverado
1964 Cadillac
Old 12-15-2009, 04:51 PM   #18
redsled04
redsled04's Avatar
I dont think bags are legal in most states ethier.You can buy a screw on safty cap if your worried.Like the one moble welding trucks keep on their bottles looks like a cap with a hole in it.
Old 12-17-2009, 12:24 AM   #19
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Dont think bags are illegal anywhere in the US, as semi trucks run them all across the country
Ride height though, now there is something that is regulated & can be illegal Its really more about light heights, but close enough lol
My bug is WAY below the legal limit
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 12-23-2009, 12:57 AM   #20
Driveway Dreams
I have car A.D.D.
Wow, this thread got out of hand since I was on it last. We went and got the truck and then my internet was off for a bit. The kid was using nitrogen tanks to fill the in bed air tank. The truck had no compressor. It was cool, but kinda thrown together. None the less, we left the tanks there & loaded the truck on the trailer and brought it home. My buddy ordered a compressor right away and we have to find a slow leak somewhere. Any tips for that? Just squirt some soapy water on it and watch for bubbles?
-Gerald
Old 12-23-2009, 01:27 AM   #21
ShowSS12
ShowSS12's Avatar
Yup thats pretty much it.
Adam M
STX Designs
Old 12-24-2009, 12:49 AM   #22
Driveway Dreams
I have car A.D.D.
Well, I thank you all for the advice so far. I will get a pic of it to show you all what I have been asking about. I am sure more questions will come up and I will be sure to ask them in here.
-Gerald
