Old 12-11-2009, 12:44 AM   #1
texasfunk
texasfunk's Avatar
need urgent help quick!
with my luck, thismorning in 20 degree weather my alternator gave out at the halfway mark on my daily trek to school, and of course with a hi-po ignition system the battery didnt get me too much farther on its own, i managed to get a trailer frm my instructor and got it to class, my ? is, i have an alternator from a 96 (which i know is a different design but will fit) that i want to take and put it on to get my truck home,problem is, the single wire plug on the truck wont fit into the 96 alternator, and i cant for the life of me find the plug to the 96 alternator(used to be on my truck) my question is, is it absoloutley necessary? can i get the truck home with the alternator hooked up but not plugged in? thank you for any help!
2006 GMC Sierra CCSB, 6.0 swap
2000 Chevy C3500 Crew Cab shortbed dually
1999 Chevy c2500 Crew Cab shortbed
1982 El Camino 350/350
1979 K5 2wd blazer bagged/bodied
1986 Monte Carlo SS
1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4
1955 Chevy Bel Air
2014 Chevy Silverado ccsb
texasfunk is offline   Reply With Quote
Old 12-11-2009, 01:00 AM   #2
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
Re: need urgent help quick!
what does the hook up look like alot of times you can use a spade connector to make the connection and then get the plug later.
staggerd86c-10 is offline   Reply With Quote
Old 12-11-2009, 01:10 AM   #3
72lb4x4
With a good charge on the battery, I would think the truck will run for quite a while without a working alternator. Are you sure you don't have another problem?
72lb4x4 is offline   Reply With Quote
Old 12-11-2009, 07:08 AM   #4
billnorman
What he said.
billnorman is offline   Reply With Quote
Old 12-11-2009, 11:54 AM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
dont try to rig this you will fry the harness... When your alternator goes out, you run off the battery and you can and will cook the battery. The longer you run it this way you heat up the lead plates and the acid ( water) evaporates.
The correct thing to do is to have the battery charged and filled and replace the alternator..with the proper one
In addition the unplugged 96 alternator is like keeping the original non working alternator.. it does nothing
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-11-2009, 01:32 PM   #6
Damien
Damien's Avatar
You have to fill the battery then charge it. It you do it the other way around it won't work.
How long of a drive is it? My saturn made it about 40 miles with a bad alt.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 12-11-2009, 02:31 PM   #7
texasfunk
texasfunk's Avatar
thanx for the info! luckily i dug around the garage this morning and found the plug! and it wont run far, something is draining the battery also and havent found it yet, plus, i dnt want to fry it, i put the 96 alternator on and it runs great, got her home, where she will sit for a while, starting the bodywork
1986 Monte Carlo SS
1955 Chevy Bel Air
