Old 12-11-2009, 06:10 PM   #1
firsttry1971
firsttry1971's Avatar
5 bolt to 6 bolt????
hey what would i have to do and need to get to switch to 6 bolt hubs??
thanks
firsttry1971 is offline   Reply With Quote
Old 12-11-2009, 06:15 PM   #2
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: 5 bolt to 6 bolt????
uh, not trying to be a D---... but why do you want to do that?
LOW DOUGH is offline   Reply With Quote
Old 12-11-2009, 06:17 PM   #3
firsttry1971
because than i want to put some 17 in rims on it that i found but they only come in 6 bolt.
Old 12-11-2009, 06:26 PM   #4
mcbassin
Still Learning
mcbassin's Avatar
thanks
If you want 6 hole disk brakes up front you will to buy some aftermarket rotors. If you want to go back to drum brakes on the front you will need all the old stuff. On rear you will need etiher axles or a whole rear end.
What about adapter plates?
Good luck
Mike
mcbassin is offline   Reply With Quote
Old 12-11-2009, 06:36 PM   #5
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
since its a 71 you will need 6 lug rotors and MAYBE you can fnd a 70 only axle which came in 2 sizes then you can just pull the axle shafts and drums...
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 12-11-2009, 06:38 PM   #6
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
you would need the wider axle. Hottrucks forgot to say that part. I got your back
Old 12-11-2009, 08:08 PM   #7
68gmsee
Active Member
68gmsee's Avatar
Been on this site for many years and all I've heard is how to convert to 5lugs. But, it was bound to happen... going retro.
68gmsee is offline   Reply With Quote
Old 12-11-2009, 08:14 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
Just make sure the "center bore" of the wheel is the same size as your 5-lug hubs.
Most late model 17" 6-lug wheels have a smaller center bore.
Keith
Convert to disc brakes.
Old 12-11-2009, 08:59 PM   #9
firsttry1971
hey thanks for the info guys
