12-11-2009, 06:50 PM | #1 |
3/4 to 1/2 to 3/4 ton question
My 84 was originally a 3/4 truck. The previous owner converted it to 1/2 ton before I bought it. Now I am about to tear back into it but since there is 5 people in a 4 hour drive of me doing a crew cab long bed with 1/2 ton suspension, I am going in a different direction and want to go back to a 3/4 ton. I was wondering if I could just change the rear end, and up front swap the rotors or do I need to swap spindles too?
12-12-2009, 02:20 AM | #2 |
Re: 3/4 to 1/2 to 3/4 ton question
Everything I've read on these 3/4 to 1/2-ton conversions indicate the need to swap spindles. I would say you'll need some 3/4 ton spec'd spindles (which are available in dropped form if desired).
12-12-2009, 12:01 PM | #3 |
Happy to be here
To complete the conversion you will need to change the rear leaf springs if you want the carring capacity.
I "think" the springs are wider, so you might need the correct hangers too. Someone verify this please.
12-12-2009, 12:22 PM | #4 |
well, i have a 3/4 ton, and i have a friend that has a 1/2 ton, and all i can tell you is that the suspension is Very stiff, i went over a speed bump going 20mph, and i went air bourn in my cab, ,
12-12-2009, 11:26 PM | #5 |
my truck is bagged so leafs are not a worry of mine. Sry, I forgot to put that in my post. I am wanting to do a dually conversion on my truck so I need to get back to 8 lug pattern. I know I need to get a C&C rear end but I was wondering what about the front if its just a rotor and spindle swap or do I have to swap the motor crossmember out too.
12-14-2009, 07:02 PM | #6 |
Ive posted a link to a wright up I did on front end's a few times on here
http://duallyscene.com/forums/viewtopic.php?f=27&t=4359
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
12-14-2009, 07:14 PM | #7 |
Thanks! that is exactly what I am looking for.
