Old 12-11-2009, 08:37 PM   #1
lonelywanderer
floor or trans mount shifter?
looking to pick up a lokar or gennie shifter for my 59 and was wondering which one would be better? the truck has a floor mounted shifter at the moment but i seen they offer the floor and trans mounted ones.
and would it be better to get the single bend or the double bend one?
lonelywanderer is offline   Reply With Quote
Old 12-11-2009, 10:32 PM   #2
blackdiesel
blackdiesel's Avatar
Re: floor or trans mount shifter?
I've used both, the foor is cheaper and not as sturdy unless you reinforce the floor. In short I put the tranny mount in my 57. and I used the floor mount in my streetrod.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 12-12-2009, 12:35 AM   #3
OrrieG
OrrieG's Avatar
When I converted mine I used a 67 Camaro shifter mounted on the floor without any problems. Had to modify the detent plate for the additional shift point.
OrrieG is offline   Reply With Quote
Old 12-12-2009, 09:11 AM   #4
49ZR2
49ZR2's Avatar
I used a Locar trans mount in mine. I really liked the way it mounted. Easy to install and looks good to.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=372267
49 4x4 build
51 Willys frame off beer getter.
49ZR2 is offline   Reply With Quote
Old 12-14-2009, 01:40 AM   #5
lonelywanderer
it does look good in your truck. i think i'm going with a trans mounted set up, now to decide if i want the swan neck style like the above pic or the single bend shifter
Old 12-14-2009, 06:10 PM   #6
entourageguy
Yellow truck club
entourageguy's Avatar
If your running a bench seat the double bend works better for clearance for the middle person.
Iv'e got the single bend and will be changing to double.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 12-14-2009, 10:08 PM   #7
lonelywanderer
^you just help me make up my mind. i have the bench seat and i plan to leave it in. double bend it is. thanks
Old 12-15-2009, 09:38 AM   #8
Richard H.
Spanked once
Richard H.'s Avatar
I gotta change mine also for the same reason ,other than that it is nice setup.
The ole 350 budget build.
Richard H. is offline   Reply With Quote
