Saginaw 4 speed Swap
I currently have a saginaw 3 speed on the column, and I plan on putting a rebuilt saginaw 4 speed in place of it. I know the cases are interchangeable, but I want a floor shifter. Anyone know which one works for our trucks? Thanks.
Re: Saginaw 4 speed Swap
i just tossed all the linkage for what your looking for. Do a search on google there is a kit you can buy.
My main concern is the shifter rod, the height and bend? Does anyone have any suggestions for this?
I did mine back in 1980; at that time there was a specific Hurst (or Mr Gasket) application for a pickup truck with a bench seat.
I'd say check the parts books and see what you can find. Good luck - K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Figured it out, had to get the Hurst Indy universal 4 speed shifter, then a replacement shifter arm for a Hurst 3 speed truck shifter with a bench seat. Fits together perfect, don't have it in the truck yet but it looks like it will work perfect.
fan of "Butters" Stotch
Glad to hear! my truck will be getting a 4 speed Saginaw later this winter. Did you buy a new one, or did you find a used one somewhere?
64 shortbox fleetside replacing rusty junk with more junk, and one day to become a real truck again ![]() Last edited by tapeworm; 12-19-2009 at 08:37 PM. |
I got mine on craigslist, a guy had it rebuilt for a camaro but then he sold the car.
No No
You are correct the hurst shifter works fine. I did the swap a long time ago used a saginaw 4 speed from a car. Wasent to happy 1st gear was useless ended up going back the the 3 speed.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
What were your gear ratios? I have a 3.11 first gear saginaw, and I have 3.73's out back. I am going to redo the rearend pretty soon, and I was debating a 3.73 or a 3.42 for more street friendly driving, but since my main concern is acceleration I decided on the 3.73's, though I havent got the ring gear and pinion yet.
Tags |
swap muncie trans saginaw |
