Old 12-12-2009, 10:06 AM   #1
ges55
BLACK SATIN
ges55's Avatar
? about 67 hubcaps
Can someone show me what options were available for hubcaps on a 67 C10? I had some painted ones (not any more) & they didn't look like some of the more rounded ones I have seen on here. I would like to eventually get some of the correct ones. Thanks for any help.
67 C10 Fleetside LWB-283, 3 on the tree,power assisted steering, father-in-law bought it new
67 C20 Fleetside LWB-'85 305 V8 (original was 250 6 cyl), Holley 600 carb, full length Hedman headers, dual exhaust behind the back wheels, 4 spd , manual steering
85 C10 Silverado- 305ci
ges55 is offline   Reply With Quote
Old 12-12-2009, 10:52 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: ? about 67 hubcaps
Here's one type...
Hart_Rod is offline   Reply With Quote
Old 12-12-2009, 11:29 AM   #3
NC67Chev
NC67Chev's Avatar
I have the original white and orange ones on my truck. I can take a close up if you need it.
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside
Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar
NC67Chev is offline   Reply With Quote
Old 12-12-2009, 11:30 AM   #4
nds1968
nds1968's Avatar
Here some I have forsale. http://67-72chevytrucks.com/vboard/s...d.php?t=376022
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 12-12-2009, 11:34 AM   #5
nds1968
nds1968's Avatar
Here are the painted and stainless that are correct for a 67.
Nate
Old 12-12-2009, 11:43 AM   #6
Duncan and son
Hey Rob, Good looking truck...My kind of truck " As it was, Not as you wish it was"
You can shear a sheep every year, but you can only skin it once
The person dealing with facts is never at the mercy of the person dealing with theory
1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn
1975 Silverado 454 Crew cab camper special dually
Duncan and son is offline   Reply With Quote
Old 12-12-2009, 02:28 PM   #7
Hart_Rod
Hart_Rod's Avatar
Thanks Mr. Duncan. The outside is all original, under the hood not so much.....
Old 12-12-2009, 03:38 PM   #8
ges55
BLACK SATIN
ges55's Avatar
What year are these supposed to go with? This is a 3/4 ton 16" wheel.
Old 12-12-2009, 04:51 PM   #9
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
those were 73 and up if i am not mistakin.
I really wish I had a set of those dog dish caps from a 67 posted at the top. painted or stainless... it dosen't matter. But, then I would need the wheels to hold them.
LOW DOUGH is offline   Reply With Quote
Old 12-12-2009, 09:39 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
This isn't anything like a 67/68 3/4 ton hubcsp... that wouldn't even go on a 67/68 truck
Old 12-13-2009, 08:41 AM   #11
68 was the last year for clip-type hubcap mounting.The clips require a special inner lip on the hubcapIin`69 the nub-type began use on the 8-lug trucks.That`s the design used ever since.69-72 used blue on all bowties.The ones with yellow bowties are 73-75.
Old 12-13-2009, 09:48 AM   #12
ges55
BLACK SATIN
ges55's Avatar
Weren't there some kind of clips on my original 3/4 ton split rims? Is that what they were for?
Old 12-13-2009, 09:53 AM   #13
ges55
BLACK SATIN
ges55's Avatar
Thanks for all the great info, guys. So the 1/2 ton & 3/4 ton caps looked the same?
Old 12-13-2009, 12:03 PM   #14
factorystock
factorystock's Avatar
How about removing clips from a split rim wheel and rivit them on to a newer ( mid 80's ) 8 lug wheel ?
factorystock is offline   Reply With Quote
Old 12-13-2009, 12:07 PM   #15
factorystock
I should answer the question first before the suggestion. Yes, the 1/2 and 3/4 caps look the same from the front, but the backs have different measurements.
