12-12-2009, 03:33 PM | #1 |
The oddest Todd around
Gear Shift lever
Is this the gear shift lever for an automatic or standard (both on the column... of course)?
I ask, because I have an automatic, and this shift lever has always seemed... sloppy. Toad
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan IIOY??? |
12-12-2009, 05:28 PM | #2 |
Re: Gear Shift lever
Nobody knows?
12-12-2009, 05:29 PM | #3 |
My "standard" looks like that one.
12-12-2009, 05:41 PM | #4 |
That's what I'm thinking, is that I have a standard gear shift lever instead of an auto.
12-12-2009, 06:05 PM | #5 |
Standard. Auto has does not have that little point
12-12-2009, 08:25 PM | #6 |
Well... then believe me when I say we all learned something new here today.
We've all learned that a standard gear shift lever CAN be used on auto column. But also believe me when I say that they don't work well. I think the auto lever must be thicker or something, because the standard shifter is really loose in the column.
12-12-2009, 08:30 PM | #7 |
My auto shifter was sloppy as well - there is supposed to be a rubber grommet on the business end of the shift lever - I replaced mine and it tightened up the feel signifigantly.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
12-12-2009, 08:33 PM | #8 |
Well... the only way for me to shift into either 2 (or 1) is to put it in park, and then QUICKLY slam it down into 1. I can't just slide if from D into 2. It won't move.
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan IIOY??? Last edited by toddtheodd; 12-12-2009 at 08:33 PM. |
12-12-2009, 09:23 PM | #9 |
i ordered that same shifter handle from LMC for my 71 auto non tilt column, but where do i get the rubber gromet???? my shifter is wicked sloppy as well and LMC doesnt have the pin that goes through the hole where can i find that the one from the tilt column is a different size i think wont fit in the column side of the hole?
12-12-2009, 10:21 PM | #10 |
my auto lever looks different on the end , wish i could take pic. but , mine goes on a tilt don't know if there's a difference with non-tilt .
12-13-2009, 12:26 AM | #11 |
i have both the auto is a little longer yhan the standard
12-13-2009, 10:25 AM | #12 |
Sounds to me like I need to find the auto lever.
12-13-2009, 04:54 PM | #13 |
Just like to part out trucks!!
I beg to differ with everyone but what you have is a automatic shifter, here ar a couple I have, both off automatics, the one on the top has a bushing on it so there isn't any slop. I've got probably 10 shifters out there out of auto's and all are the same as these, I know for sure I haven't had a 3 speed truck around here for years.
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
12-13-2009, 05:23 PM | #14 |
So why can't I go from D to 2 (or 1)?
Why do I have to quickly slide if from P to 1?
12-13-2009, 05:26 PM | #15 |
Oh, and the slop I'm talking about is that the lever is x millimeters wide, and the hole in the column that it goes into is y millimeters wide, which is z millimeters wider than x...
I'd say, 2 to 3 millimeters wider. So that in D, I can move the end of the shifter about 4 inches before it goes into N, and I have to tap, tap, tap it into N, because it doesn't "click" into N like it should.
12-13-2009, 08:05 PM | #16 |
The Older Generation
If that cotter key was used for a retaining pin I can see why it would be loose... LockDoc
12-13-2009, 08:39 PM | #17 |
That cotter key is the exact diameter of the holes in the shifter / column that it goes though. In fact, I had to hammer it in a bit.
It's not that hole I'm talking about... Tell y'all what... here in a bit I'll take a picture of the loose spot and post it.
12-13-2009, 08:52 PM | #18 |
This gap:
12-13-2009, 11:17 PM | #19 |
does anyone know where to get the grommet that goes on the tip of the shifter handle?? i need one too mine doesnt have any and is sloppy
12-13-2009, 11:29 PM | #20 |
It's a catastrophic success.
Gmc pauls has this, notice the yrs differences.
http://www.gmcpauls.com/auto.transmission.htm |
12-14-2009, 01:12 PM | #21 |
I would guess you will have to get a different shift collar to correct that. If you knew a good welder he could probably build up the lever and you could grind it down so it fit tight. That would do for a temporary repair anyway.
LockDoc
12-14-2009, 01:56 PM | #22 | |
12-14-2009, 02:18 PM | #23 |
Project Junkie! Fishing Poor!!
The non tilt automatic shift lever and 3 speed column shift lever are the same. Most of the slop that you guys are getting is because the nylon bushing is either warn out or missing completely. We have three of these bushings in stock. $4.95 plus shipping.
Todtheodd, you have a couple of problems going on with your column. One is the carter key that you are using for a shift lever pin and the other is a warn out collar that has been wallered out from age. The nylon bushing is probably shot also. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
12-15-2009, 08:38 PM | #24 |
i looked on your website but i couldnt find the nylon bushing in the online catalog can you type a link to the page thanks
12-15-2009, 09:10 PM | #25 |
Wes is correct on this, also the width of the shifter is different 67-70 and 71/72 as well as the collars it fits into
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
