Old 12-12-2009, 04:34 PM   #1
rattleon
rattleon's Avatar
? on modification of factory fuel sending unit
I relocated/changed the cab mounted fuel tank in my '70 short/step to the rear behind the diff. as many do with the blazer style tank. I'm using the factory sending unit/fuel pickup assembly I got with the kit. I like the tank application, but it only has what appears to be a 5/16" pickup tube for the fuel..... My question is has anyone out there ever modified, or changed the pickup tube in one of these factory sending units to 3/8" or 1/2", or is there any other options short of a fuel cell? It needs to feed a 460 BB chevy with 750 holley or bigger carb. and when I mash the pedal I don't want to starve it for fuel, especially at the beginning of the system. Easier to fix now, not later!
Thanks for any input
1970 c-10 short/step box morphing into street/strip
1967 RS/SS convertible Camaro
1932 Henry Ford steel 5 window coupe highboy hotrod
1931 full fendered model A sedan AV8 traditional hotrod.
1934 Ford 5 window coupe and a (pile-of-parts)
1929 Model A coupe, plus our "normal" people vehicles.
rattleon is offline   Reply With Quote
Old 12-12-2009, 09:22 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: ? on modification of factory fuel sending unit
That sending unit looks identical to the 67-72 units (except for the hose connection) but I'm not sure about the length. If it's the same length you can get a new sender with the 3/8" tube.
LockDoc
Leon
Old 12-13-2009, 11:19 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if that is a blazer tank, then you need a blazer sending unit for a v8 blazer... they came stock with a 3/8. Get a 60/70 if you don't want a return line.
