Old 12-12-2009, 05:06 PM   #1
66GMC-Canuck
66GMC-Canuck's Avatar
Question Tilt Column in a 66 GMC
Folks,
looking to pickup a tilt column for my 66 GMC. Can you guys tell what year donor vehicles I should be looking for. I can pick up a complete column from a 82 Surburban will that fit? don't mind if I have to modify it.
Got a couple of yards around here and just need a guide to help in choosing. I have read the tilt threads but they are not so specific on whats best donor.
66 GMC 1500 Series LWB
66GMC-Canuck is offline   Reply With Quote
Old 12-12-2009, 05:29 PM   #2
62gmc910
62gmc910's Avatar
Re: Tilt Column in a 66 GMC
To the best of my knowledge the tilt column from '73-87 was basicly the same they are a bit larger od at the mounting point ,I would avoid those with a multi function switch cause they were a pain when new, If you pop the epoxy, the colapsable end will shorten up enough to bolt to the rag joint
The suburban 2wds shared the suspension /brake parts with the pick ups of the same series so they are good donors
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 12-12-2009, 07:42 PM   #3
62 short step
62 short step's Avatar
67-72 column would work also.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 12-12-2009, 07:44 PM   #4
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I believe the Van columns are the 'choice' ones...Vans with dash ignitions
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 12-12-2009, 08:16 PM   #5
66GMC-Canuck
If anyone could post pics of the tilts they have in their trucks that would help.
Old 12-12-2009, 09:04 PM   #6
Chevy Fleetside
Chevy Fleetside's Avatar
70's Van Column. The van column is short, and you have to use a u joint. The positive is that you can use a collapasable steering shaft. I welded a couple of nuts to the column to bolt up the mount plate too. The other differnce is the harness plug.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 12-12-2009, 09:05 PM   #7
Woogeroo
lots of links and various tidbits of information here:
tilt steering for our trucks, aftermarket or later model swap ins?
Woogeroo is offline   Reply With Quote
Old 12-12-2009, 09:35 PM   #8
Oklahoma
Out of a 93 s-10 in a 62
Oklahoma is offline   Reply With Quote
Old 12-12-2009, 09:36 PM   #9
Oklahoma
Woops
Old 12-12-2009, 10:06 PM   #10
66GMC-Canuck
Are you using the ignition key in the column?
Old 12-12-2009, 10:09 PM   #11
66GMC-Canuck
Thanks for that link. I missed those pages lots of great info.
Old 12-12-2009, 11:32 PM   #12
70 Suburban
Rods
check alans build He did a play by play.. and removed the key or the colomn shift...
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 12-13-2009, 02:24 AM   #13
DPowers
DPowers's Avatar
'64 Impala in mine.
DPowers is offline   Reply With Quote
Old 12-13-2009, 06:15 AM   #14
66GMC-Canuck
Be cool if you guys could post how you fit your column. Easy or not so easy? appreciate the info and help.
I will check out Alans thread.
Old 12-13-2009, 11:44 AM   #15
70 Suburban
Rods
lol good luck im not sure what page its on.. it might take a good day or two of looking...
Old 12-13-2009, 11:48 PM   #16
DPowers
DPowers's Avatar
Some info here
http://67-72chevytrucks.com/vboard/s...d.php?t=362864
Old 01-21-2010, 05:45 PM   #17
66GMC-Canuck
I finally found a good tilt column to use. Got a rebuilt column from a 73 Chevy van coming. Got a great price including shipping to Canada so cannot complain. Want to get that in as soon as possible as my original column needs work. So best of both worlds. Get me a tilt and a rebuilt one to boot. Can soon strike that off my list. Only 900 items to go LOL
Old 01-21-2010, 09:28 PM   #18
tripleD
tripleD's Avatar
77 nova and still keep your key switch on dash or find older van.
triple d
tripleD is offline   Reply With Quote
Old 01-21-2010, 11:22 PM   #19
DPowers
DPowers's Avatar
Cool- you do know that 900 item check off list usually goes up more times than down....
