Old 12-12-2009, 05:38 PM   #1
56 3100
56 3100's Avatar
1956 rear tub?
hi everyone i am gonna put 31 16.50x 15 tires on the back of my 56 3100 stepside tires just came bed side a small amount. what does anyone have for pics/ideas for a small wheel tub. the ones CPP sell would work but where they are fiberglass i am worried about chips(if i take it to the drag strip sticky tires). i will be using wood bed floor.
56 3100 is offline   Reply With Quote
Old 12-12-2009, 07:27 PM   #2
moonshinner
Re: 1956 rear tub?
late 70's early 80' chevy wide bed cut the wheel wells out works good or 55 gal drums cut in half
moonshinner is offline   Reply With Quote
Old 12-12-2009, 08:44 PM   #3
mixermike
mixermike's Avatar
Re: 1956 rear tub?
try these guys http://www.stylinsolutions.com/ec/Product.aspx?ID=3052
mixermike is offline   Reply With Quote
Old 12-12-2009, 09:15 PM   #4
2tons of fun
Re: 1956 rear tub?
stock outers on the inside. throwing some cheesy flat steel in always looks hack and lazy.
2tons of fun is offline   Reply With Quote
Old 12-12-2009, 09:31 PM   #5
OrrieG
OrrieG's Avatar
Re: 1956 rear tub?
would a 58-59 fleetside tub work??
OrrieG is offline   Reply With Quote
Old 12-12-2009, 11:56 PM   #6
56ClassicTruck
Re: 1956 rear tub?
What rear end are you using for the tires to be in so far?? would like to put some big tires like that in my 56 any pic of the tub work...
56ClassicTruck is offline   Reply With Quote
Old 12-13-2009, 05:32 AM   #7
2tons of fun
Re: 1956 rear tub?
you can make anything "work".
Old 12-13-2009, 09:32 AM   #8
entourageguy
Yellow truck club
entourageguy's Avatar
Re: 1956 rear tub?
I used a pair of early 60"s tubs and cut them down to about 8".
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 12-13-2009, 10:03 AM   #9
lakeroadster
Re: 1956 rear tub?
I went to the local tractor supply,bought a trailer fender and modified it. Then bought a stock angle bracket and mitered it to fit around the mini-tub.
lakeroadster is offline   Reply With Quote
Old 12-13-2009, 08:07 PM   #10
56 3100
56 3100's Avatar
Re: 1956 rear tub?
thanks everyone. i am using a narrowed 9" 56" wide drum to drum. lakester you idea i will check into as the trailer fender are reasonably priced around here. do you have yours finished yet? i would make mine so they bolt on i think.
Old 12-13-2009, 08:14 PM   #11
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: 1956 rear tub?
I was going to use the 58-59 fleetsides, but have since decided to go with 67-72 suburban wheel wells. They will have to do cut down, but I like the radius and they have a similar flange on them like the bedsides.
ChuckDriver is offline   Reply With Quote
Old 12-13-2009, 08:17 PM   #12
ChuckDriver
Re: 1956 rear tub?
Here's some other examples.
Old 12-13-2009, 09:35 PM   #13
56 3100
56 3100's Avatar
Re: 1956 rear tub?
thanks chuck great pics. is first pic 58-59 fleet side? hard to find in good shape.?
Old 12-13-2009, 10:00 PM   #14
ChuckDriver
Re: 1956 rear tub?
These are the 58-59's that I have.
Old 12-13-2009, 10:54 PM   #15
56 3100
56 3100's Avatar
Re: 1956 rear tub?
the surburban fender well do have a nicer look chuck. thanks for pics.
Old 12-16-2009, 02:43 PM   #16
56 3100
56 3100's Avatar
Re: 1956 rear tub?
orrieg the 55-59chev panel ones have flange like 67-72 burbs.
