12-12-2009, 06:06 PM | #1 |
A few simple questions
First off, do i need new motor mounts for a small block to big block swap? Secondly, what all is entittled with a automatic to standard tranny swap. third-ly how do you figured out what spline the axles are and what does that mean really. Also a ford nine in ch swap. and finally a 1/t ton 5 bolt pattern is 5x5 right? and does weld make prostars in that pattern? Thanks lol
1970 Chevrolet custom camper 20 2000 F@$d F250 Powerjoke "And i still like bologna on white bread now and then" -Alan Jackson |
12-12-2009, 07:04 PM | #2 |
Re: A few simple questions
See if I can answer all these.
SBS-BBC, mounts are the same, been there done that 4-5 times now. Auto-stick, ALL the peices meaning=stick column, pedals with linkage or hydro stuff, bellhousing if it's not on the tranny, if your truck is 4wd, front shaft should work, rear might need to be lengthened, crossmember, cut a hole for the shifter or if it's a 70s truck unbolt it and bolt in a stick hump. What year is your truck?? What axle?? If the one in your sig, 12 bolt, think they are 30 spline but don't hold me to that. GM truck is 5x5.5", go to Summitracing.com, and search for your bolt pattern.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
12-12-2009, 07:17 PM | #3 |
hoh ok. its a 77. sorry when i did the name i didnt even thimk about it and i named it after the camaro. can i use the same column just remove the shifter? and its a twelve bolt. is a twelve bolt just as strong? and have you ever done a posi swap?
1970 Chevrolet custom camper 20 2000 F@$d F250 Powerjoke "And i still like bologna on white bread now and then" -Alan Jackson Last edited by Colesnsty68; 12-12-2009 at 07:19 PM. |
12-12-2009, 07:25 PM | #4 |
1949 Five Window, 1973 Step Side, 2000 Z71 |
12-12-2009, 07:26 PM | #5 |
alright are we sure on the 5x5?
12-12-2009, 07:28 PM | #6 |
yes and you can still use your column
12-12-2009, 08:13 PM | #7 |
Sorry, haven't had anything 5 lug in years...haha.
You can use your auto column, just will have the base of the shifter to look at.
12-13-2009, 12:32 PM | #8 |
it's alright, i wish it was a 3/4 ton. so its a 30 spline? and thanks for the help
