Old 12-12-2009, 09:25 PM   #1
57larry
84 A arms on a 72
any advantages on putting 84A arms on a 72 that has factory disc brakes? better ball joints or anything?
57larry is offline   Reply With Quote
Old 12-13-2009, 12:21 AM   #2
ERASER5
ERASER5's Avatar
Re: 84 A arms on a 72
The later arms have rubber bushings instead of metal bushings. Some will tell you the rubber bushings ride better. I know the ball joints are different too, but I doubt they are much better. The BJ tapers are different from 72 to 73 which dictates the correct spindle and tie rod ends.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 12-13-2009, 11:42 AM   #3
Hart_Rod
Hart_Rod's Avatar
Ball joints are quite a bit cheaper. I think the stud is a little bigger also.
Hart_Rod is offline   Reply With Quote
Old 12-13-2009, 08:00 PM   #4
57larry
so---would this be a good swap?
Old 12-13-2009, 08:13 PM   #5
lofly'a
lofly'a's Avatar
my opinion would be yes. the only benefit i have "heard" of (since i've never used the 67-72 type) is that the 67-72 versions handle better since there is less rubber deflection for cornering/handling. the advantages are softer ride unless you use urethane cuz they are stiffer, cheaper replacement costs, IMO easier to change, no servicing (no zerks to grease), and easier to find.
i changed my blazer to 73 up before i drove it and am doing the same on the 71 even though it is already a 5 lug and disc brake setup.
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 12-13-2009, 10:10 PM   #6
57larry
so then, are front end parts cheaper for a 73 than a 72? I want to rebuild the front end of my 72 and go with drop spindles
Old 12-13-2009, 10:34 PM   #7
63chevyll
gets board easy.......
63chevyll's Avatar
put 73 and up spindles on it, and change over to 73 and up ball joints.
Might have to change tie rod ends too? the 73 and up have bigger peices
63chevyll is offline   Reply With Quote
Old 12-13-2009, 11:41 PM   #8
lofly'a
lofly'a's Avatar
yea, most all parts are cheaper and easier to find for 73 up, and more parts are stocked locally @ parts stores too. even the spindles can be found cheaper if you search.
