No Nonsense
![]() Join Date: Sep 2009
Removing tension from the leaf springs..help
I am going to take off the rear leaf springs and would like to know where I should jack it up to remove the tension from the leafs. I have a 75' with the 8 leafs that sit on top of the axle.
Bi-Centennial Blazer ![]() ![]() |
Re: Removing tension from the leaf springs..help
there really isnt any tension of the springs. put jackstands under the frame and the springs will hang. then just unbolt them.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
yeller
If the axle is still bolted to the leafs, you need jackstands under the axle as well...otherwise it will fall to the ground when the leafs are unbolted...and could possibly injure anyone under it or around it.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 12-13-2009 at 12:37 AM. |
No Nonsense
I already unbolted the rear bolt that connects the hanger to the shackle and the leaf spring shot up and is resting on the bottom of the bed. I loosened up the front bolt and there is too much tension to remove the bolt.
There seems to be a lot of tension on the leafs maybe because they sit on top of the axle? I do have jack stands holding the rear of the truck up under the axles.
At the body shop.
Jack it up on the frame. Not the axle
" That didnt make it any newer " " Dont antique the equipment " |
yeller
You need to remove the axle first...or use jackstands under the axle and frame.
I would jack the truck up first by the axle...place the frame on jackstands...then lower the axle some, and place it on jackstands.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
your lucky the truck didnt crush you.
No Nonsense
thanks got it now. i have jack stands ounder the axle and frame.
wow...your crazy :O
1986 Chevy 3/4ton 4x4 Lift- 4" front, about 5" in the back Plans- 3" body lift and hopefully some 38" boggers.. Last edited by Krilix; 12-13-2009 at 12:23 PM. |
