Moderator
![]() Join Date: May 2007
Converting from 4WD to 2WD
How difficult is it to do this on a 69-72 Blazer? Is it a simple matter of bolting on parts from a 1/2 ton 71-72 donor truck? I have 1/2 ton front clip, and a 12 bolt rear with a coil spring set-up. Will this stuff bolt right in? Or are there differences in the 2wd and 4wd frames? Thanks.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Re: Converting from 4WD to 2WD
THE FRONT FRAME KICKS UP THE REAR FRAME DONT CURVE OUT FOR THE SPRING MOUNTS YOU CAN MOUNT THE CROSSMEMBER AND CONTROLL ARMS YOU JUST HAVE TO DRILL HOLES HERES WHAT IM PLANNING TO DO ON THE BACK OF MINE IM DOING THE SAME RIGHT NOW http://67-72chevytrucks.com/vboard/s...d.php?t=218156
70 SWB STEPSIDE 70 BLAZER 09 challenger |
You can also just use a flip kit in the back
I'm in the process of doing with all porterbuilt parts. Some of the problems I'm finding are there is not front x-member to reference the bolt for the porterbuilt. and keeping the axle in the same position in reference to the frame..
Also, changing the axle saddles is another issues, but Nathan gave me the measurements to help rectify that.. I'm sure I'll work through them, but there are some of the issues |
SKINNY TIRES RULE!
Check out this article from Sport Truck Magazine
http://www.sporttruck.com/techarticl...ion/index.html
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
