Old 12-13-2009, 06:42 PM   #1
HSH
Remove Drip Rail?
Thinking about removing the drip rail. Anyone here ever did this? If so, do you have any pictures?
HSH is offline   Reply With Quote
Old 12-13-2009, 06:44 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Remove Drip Rail?
there should be a couple places to look for threads on this.In the FAQ's and in the builds section.There may also be some mention of it in the bosy section.I know a few have done it maybe they will chime in with links.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-13-2009, 07:16 PM   #3
VA72C10
VA72C10
VA72C10's Avatar
Here's a few completed and progress I have saved.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 12-13-2009, 07:21 PM   #4
VA72C10
VA72C10
VA72C10's Avatar
And mine in progress. Just make sure to cut small sections 6-10" at a time, tack together the pieces, cut more, tack, etc. Then go back and tack between the original ones, then between those. Go slowly/space out the welds so you don't heat up/warp the metal. The be prepared for a lot of grinding.
While you're at it, shave the firewall too
Old 12-13-2009, 07:23 PM   #5
HSH
Looks smooth, thanks VA72C10.
Old 12-13-2009, 07:29 PM   #6
HSH
The firewall looks good too. What do you have in mind for heat and blower?
Old 12-13-2009, 07:41 PM   #7
VA72C10
VA72C10
VA72C10's Avatar
Vintage air/Old Air/etc. Going to go with an aftermarket A/C and heat unit under the dash.
Old 12-13-2009, 07:42 PM   #8
VA72C10
VA72C10
VA72C10's Avatar
Thanks and you're welcome. Still has a long way to go until it's ready for final body work and paint. Trying to use minimal filler.
Old 12-31-2009, 10:22 PM   #9
70 aquamarine
70 aquamarine's Avatar
it is alot of work to smooth your dripm rail i did because mine was rusted out it is alot of welding
70 aquamarine is offline   Reply With Quote
Old 12-31-2009, 10:25 PM   #10
Lugnut64052
Middle-aged Curmudgeon
Lugnut64052's Avatar
There have been threads on this from time to time. Be careful though-- the drip rail is part of the cab structure and where the skins all weld together right at that point. Do just a few inches at a time.
Bret
Check out the site's Truck Tech FAQ.
Be a site supporter.
My more-or-less pathetic build thread.
Board members I've met:
Longhorn Man
Dieselwrencher
jholley
big mike71
Lugnut64052 is offline   Reply With Quote
Old 12-31-2009, 10:44 PM   #11
dnd1978
dnd1978's Avatar
It is a BIG job. Read this it all help.
http://www.customclassictrucks.com/t...rty/index.html
dnd1978 is offline   Reply With Quote
