lowering blocks question
anyone have any pic of rear coil with lowering blocks
i have a set of 3 inch lowering blocks i want to install on my 61 chevy c10 not sure of placement> also i have had some guys telling me to just heat my coils can someone tell me the bad with heating coils? how much of a drop can you git with heating a set of coils thanks ![]() |
Re: lowering blocks question
Look at post #21 on your thread on HAMB about spacers.
and a few others
rain man, there's all kinds of info here on lowering these trucks. Just do a search for lowering and you'll find dozens of ideas. Most of us either use Jeep rear coils or I've used 70's Chevelle rear springs. But, there are dozens of options, just take the time to search here.
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
Heat is bad. Takes the temper out of the springs.
Rainman,
Hope these pics help. Also, here is the link for the installation on CPP's website. Check it out! http://www.classicperform.com/goingdown6772.htm |
hey i hope i dont piss everyone off but what is the point of having a message board if every time someone has a question you just tell him too use the search function. if you dont want to give real input then just skip the thread what is the point of beiing a d**khead. thanks for the pics
astro chimp just like i said at hamb the link in great write up but the pics arent showing up i can read but no images.
Rods
![]() Join Date: Nov 2002
Well its cut and dry.. You can only put the blocks in one place once the rear is is off the perch.
As doe heating.. Dont. its a bad ride and it makes them weak... How far down do you want to go?
Just keepin it simple. ![]() 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
not far just wanted to even out
give it a better stance |
was just looking and relized that im gona have to either git diffent wheels on tires i only have like 2 inches between fender and tire
Rods
I cut one coil on front. and 2 in blocks in back
Intentionally Left Blank
I don't have any pics, but I'd rather see you cut the coils with a cutoff wheel or sawzall. I used new springs from Early Classic. Heat (torch) will make them lose their temper and make them more vulnerable to breakage. Blocks will move the axle off of the truck arms and create more leverage front to rear when under acceleration or stopping. This could cause the U-Bolt to break. I don't know about the Jeep springs, but I've heard they work. I just don't know about how much they lower the truck....jeff
1965 C-10 Short Fleet 468/TKO 5-Speed 2004 2500HD Crew 496/Ally Blacked Out (SOLD!!) 1997 Formula WS6 2004 Jeep Wrangler (Sold) 2013 Jeep Wrangler (Sold) 2017 Jeep Wrangler (Blacked Out on 35's) 2011 GMC D-Max Dually Denali 3500HD (Sold) 2015 GMC D-Max Dually Denali 3500HD (Sold) 2018 GMC D-Max Dually Denali 3500HD (Sold) 2020 D-Max Dually Denali on 33x12.50's 1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles |
#13 | |
and a few others
If you want to get pissy right out of the box, your stay here is gonna be short.
#14 | |
Rockin' a '66 and loving every minute of it ![]() |
