rims
What would be a good offset on a 15x10 rim for my 71 4x4 1/2 ton. I really dont want them to stick out too much.
Thanks |
user # 2756
![]() Join Date: Jun 2001
I have 4.25" backspacing with my 15x10 American Racing white wagon wheels. They stick out about 2". I don't know if you'll be able to get any more backspacing than that. What size tire you going to run?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
I have 3.5" on my 15x10, but wish that I had gone to 4". The 3.5" on my 15x8 with 33 14.5 MT Bajas rubbed on boht Depending on the drag link and front leaf spring at lock. 35 14.5 on the 10" rim did not. I have 35 12.5 BFG now, and they rub on the lower part of the front fender on the passengers side, but that fender was damaged and incorrectly repaired. The BFG is quite a bit taller than the MT were, but both listed at 35". You might get away with 4 1/2" bs, but I would want to borrow a wheel and test it before spending my $.
| Bookmarks |
