Old 12-13-2009, 10:43 PM   #1
vern350
like a rock
vern350's Avatar
axle swap question
I have a 6 lug 4x4 rear axle out of a 87. I would like to slide this into my 1981 2wd. Can I pop my 5 lug axles into it? Would I need 10 bolt or 12 bolt 2wd drive axles to go into the 6 lug housing.
vern350 is offline   Reply With Quote
Old 12-13-2009, 11:52 PM   #2
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Re: axle swap question
The 87 rear will be a 10 bolt. The 81 could be either 10 or 12 bolt. Count the number of bolts that holds the rear cover on the 81 rear. If it's a 10 bolt then the 5 lug axles will work in the 6 lug housing...
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 12-14-2009, 08:38 AM   #3
78-5.3
78-5.3's Avatar
crap!!! i didnt know this so i can look for a 12 bolt 4x4 axle and slip my 12 bolt axles in!!!! what about the brakes?????
78-5.3 is offline   Reply With Quote
Old 12-14-2009, 09:35 AM   #4
68 TT
Still plays with trucks
68 TT's Avatar
If you swap out axles check the dimensions of the brake drums on the 4x4 housing. I have heard some have bigger drums but can't tell you for sure. It could be as simple as swapping out axles & drums if the brakes are the same size.
If they end up being different as long as you put the backing plate assembly and axle/drums from your 5-lug rear end on the 4x4 housing everything will work.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 12-14-2009, 09:38 AM   #5
68 TT
68 TT's Avatar
The emergency brake cables coming out of the backing plates may be longer on the 4x4 version too so you might want to check that too.
It's probably best to just put the 5-lug backing plates & brakes on there with the axles / drums. It's only four more bolts per side if you already have the axles out so no big deal.
Old 12-14-2009, 11:32 AM   #6
78-5.3
78-5.3's Avatar
great !!!!!!!!! thx
Old 12-14-2009, 09:25 PM   #7
vern350
like a rock
vern350's Avatar
Currently has 12 bolt diff, wanting to put 10 bolt 4x4 in. Can I use the 12 bolt axles or do I need to find some 10 bolt axles?
Old 12-14-2009, 09:32 PM   #8
silverbullet01
question,
Why are you swapping the 12 bolt for a 10 bolt? 12 bolts are stronger....
silverbullet01 is offline   Reply With Quote
Old 12-14-2009, 09:47 PM   #9
vern350
like a rock
vern350's Avatar
Temporary fix for a posi diff with steeper gears until I get the 12 bolt rebuilt with new posi, currently 3.07 open diff. I think a 3.42 Posi will be better for the mean time, just got to be easy on the pedal with the gov. bomb.
Old 12-14-2009, 10:17 PM   #10
benoit454
Chris
benoit454's Avatar
good info we've found some 4x4 rearends around here but no 2wd ones, and if they are both 10 bolts and you can swap axles that be very easy.
We have an 84 with a 2.72 or 2.73 gov loc 10 bolt and want 3.73 or 4.11 setup.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 12-15-2009, 12:04 AM   #11
72 CustomCamper
huh ???
10 bolt axles have 28 spline shafts from 78-87. 12 bolt axles have 30 spline shafte from 73-81...
Old 12-15-2009, 07:34 PM   #12
vern350
like a rock
vern350's Avatar
thank you
Old 12-15-2009, 07:58 PM   #13
72 CustomCamper
huh ???
No problem...
