Old 12-13-2009, 11:11 PM   #1
HOGDADDY
HOGDADDY's Avatar
swapping gauges for non-gauges
Can I swap my non-gauges to gauges and use same wiring harness. Is the connectors the same for the temp and (electric) oil pressure.
I will buy the correct sending units.
What about the battery gauge, is that wire still present but un-used?
I have a 91 suburban gauge cluster it has a mechanical speedometer hook-up.
The 91 gauge look same on right side (large fuel gauge,speedo)
The oil is in same place, the temp and battery different positions.
Thanks in advance.
HOGDADDY is offline   Reply With Quote
Old 12-14-2009, 12:32 AM   #2
HOGDADDY
HOGDADDY's Avatar
Re: swapping gauges for non-gauges
Anyone have a wiring diagram for 86 trucks?
Old 12-14-2009, 02:46 AM   #3
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Best thing to do is study the circuit boards on the back side of each cluster. make a note of each connection and where it goes.
If you take a look at the sides of your connector on the harness, you'll notice it's numbered on the left side from top to bottom 1-9 and on the right side from bottom to top10-18. make a chart to correspond with this listing your O.E.M. cluster as well as one for your replacement cluster. If there are any differences, you'll have to re-pin your connector to match your replacement cluster.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 12-14-2009, 09:49 AM   #4
68 TT
Still plays with trucks
68 TT's Avatar
Don't forget to change out the senders too. The warning lamp pieces are different than the actual gauge senders.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 12-14-2009, 05:35 PM   #5
crossy
Oh,you can't buy that new
crossy's Avatar
Oh, ive done it and it's not for the electrically handicapped. LOL
the wiring cluster for gauge vs. NON gauge is different. like BLE said FOLLOW each gauge wiring across the back of the PC and mark it. makea chart of each and compare. you CAN move wires in the connector. i recently installed a 76-77 dash in an 81 and about 5 wires had to move. Senders are important, they are completely differnt and you will have to go by theyear of your dash. i dont think your cluster is from a 91 tho with a mechanical speedo. good news is your starting with an 86 which MAY have some needed wiring already in place. crossy
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
84,C10 SWB-Yella,stock
86 K10 SWB-Red, hopped up 305,4/S
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 12-14-2009, 07:36 PM   #6
HOGDADDY
HOGDADDY's Avatar
The cluster came from a 91 I removed it myself in salvage yard (could have been swapped I guess). It does have the green box (vss?) thing behind speedometer.
It looks like the speedo and fuel gauge would fuction as is. I am just gonna remove the green box. mechanical speedo piece still attaches same.
I also noticed it has a "service engine soon" light where mine has an un-used choke light.
I may give it s shot and try change some pins on connector. The cluster is in excellent condition.
It has a 4speed auto selector I removed but still have cause I need it.
I am thinking that empty slot would make an excellent place to put my tranny temp gauge or even a clock.
Old 12-14-2009, 10:46 PM   #7
BLE 'BURBAN
Or an air pressure gauge or a vacuum gauge.....
